Backup for dropping the gear
Old February 26th 04, 05:14 PM
Paul Tomblin
In a previous article, john smith said:
Paul Tomblin wrote:
On the Lance (which is the only plane I have any experience with), even if
you lost hydraulic fluid, air pressure would hold the gear up against the
springs until you dropped down to max gear extension speed. I suspect
you'd get a bit more drag from the gear drooping slightly into the
airstream, though.
Okay Paul, I have to ask you to explain those two statements.
What don't you understand? In the Lance, the hydraulic system is there to
raise the gear. Besides manually lowering the gear, there is an automatic
gear extension system and a manual emergency gear extension system.
If you activate the manual emergency gear extension system, springs and
gravity bring the gear down - I'm not entirely clear if hydraulic pressure
helps bring them down if you use the normal gear extension. The
description of the emergency gear extension system in the POH says that
the speed the gear will come down is lower if the plane is developing
power because the prop slipstream holds it up.
I'm told (I haven't verified it yet) that if you activate the emergency
gear extension when you're above max gear speed, the gear won't come down,
but will come down slightly into the airstream developing drag.
Paul Tomblin http://xcski.com/blogs/pt/
"The way I see it, unless we each conform, unless we obey orders, unless
we follow our leaders blindly, there is no possible way we can remain
free." - John Ashcroft^W^WFrank Burns
Old February 26th 04, 09:58 PM
john smith
airstream, though.
I do not believe the air flowing under the wings will hold the gear up.
If the hydraulic pressure is released, the gear will come down.
If you are flying fast, the air may grab the gear doors and possibly rip
them off or otherwise torque/twist the gear (whichever comes first).
Look up stories about the P-51B (or C?) and the redesign of the gear
uplock. Granted, you do not have the Mustang's cruise speed, but the
principle is the same if you exceed Vge/Vgo.
The override prevents the gear from automatically deploying.
You still have to push the lever to release the hydraulic pressure to
enable the gear to drop. The POH further says to kick the rudder right
and left to create a sideward airload on the gear to lock it into
position. In some cases, you must stall the aircraft to get the nosegear
to lock by penduluming forward as the nose drops and airload is decreased.
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance [email protected] Owning 5 July 22nd 03 12:35 AM
