Backup for dropping the gear
Old February 26th 04, 05:21 PM
Paul Tomblin
In a previous article, "Peter Duniho" said:
"Paul Tomblin" wrote in message
Actually, reading that again, it's possible that what is happening isn't
that it comes on at a lower speed if you have power on, but that the
propellor slipstream holds the gear up against the springs if you have
power on.
I don't know how the "propeller slipstream" could hold the gear up. The
only "propeller slipstream" I'm aware of is the helical movement of the air
around the fuselage, and compared to the other forces involved I doubt it's
all that strong.
The air coming off the propellor is going faster relative to you than your
air speed. If it wasn't, your propellor wouldn't be producing power.
It makes perfect sense to me. Being behind the propellor disk, the nose
gear (and possibly the mains) is experiencing more dynamic air pressure
when the engine is producing power than if you were gliding at the same
speed.
Paul Tomblin http://xcski.com/blogs/pt/
Can I LART an aol'r for attempting to subscribe to a majordomo list
with their street address, or should I wait for a second offence?
-- Allan Stojanovic
Old February 26th 04, 05:52 PM
Peter Duniho
speed.
Hmmm...I suppose so. It still seems to me like the gear enjoys such a small
portion of the overall prop thrust, and that the difference in prop thrust
airspeed and airframe airspeed is greatly reduced at or near cruise
airspeeds. But I admit, I can't imagine what else the POH could be talking
about.
Still, it doesn't explain why an engine failure would in and of itself cause
the gear to extend. Presumably the hydraulic pressure is still holding the
gear up; the prop thrust would be a backup for that, not the sole mechanism
for holding the gear up. The extension mechanism still would need to be
triggered by airspeed or MP changes.
Right?
Pete
Old February 26th 04, 06:27 PM
Paul Tomblin
Right?
If the hydraulic system was still holding pressure, then I think you're
right.
What happens if a big asteroid hits the Earth? Judging from realistic
simulations involving a sledge hammer and a common laboratory frog, we
can assume it will be pretty bad. -- Dave Barry
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance [email protected] Owning 5 July 22nd 03 12:35 AM
