In a previous article, "Peter Duniho" said:
Still, it doesn't explain why an engine failure would in and of itself cause the gear to extend. Presumably the hydraulic pressure is still holding the gear up; the prop thrust would be a backup for that, not the sole mechanism for holding the gear up. The extension mechanism still would need to be triggered by airspeed or MP changes. Right? If the hydraulic system was still holding pressure, then I think you're right. -- Paul Tomblin http://xcski.com/blogs/pt/ What happens if a big asteroid hits the Earth? Judging from realistic simulations involving a sledge hammer and a common laboratory frog, we can assume it will be pretty bad. -- Dave Barry |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 02:46 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 05:23 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 03:52 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 06:24 AM |
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance | [email protected] | Owning | 5 | July 22nd 03 12:35 AM |
