Dennis O'Connor wrote: Full stall landings are what you should be doing... With the wheels 6 inches off, the nose should be up and the horn sounding when touchdown occurs... One thing that took me a while to appreciate when I transitioned from C-172 spring steel gear to my Comanche's strut cusioned mains is that you really do need to thump slightly to compress the struts and get some traction. If you roll it on you are still flying, you just happen to be dragging your tires along at the same time. And it extends the transition between steering with the rudder and steering with the nosewheel, which in a crosswind is a recipe for getting sideways (which your mains will happily accommodate since they don't have much weight yet). -- Ben Jackson http://www.ben.com/ |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
