"Louis L. Perley III" wrote in
: Saw an article today about an aircraft that would change it's buoyancy, so it would float up like a balloon and then change buoyancy and glide down. Interesting stuff, although I doubt we'll see it anytime soon. Is something like this even practical? The article says they take the aircraft up 10 miles to get 400 miles range, In theory, yes. In practice, probably not. G It's called a blimp... One of the things that limits your aircrafts speed (or range - somewhat interchangable for this discussion) is induced drag. That comes from using part of the aircraft's power to create lift instead of forward thrust. If we reduce the weight of an aircraft (keeping everything else identical) then we can now lower the angle of attack and maintain level flight at a much lower power setting (or higher speed at the higher powr setting). Nothing new here... You can see it in any C-172 that's either light, or at gross. So now we seal off part of the plane and replace the air in there with, well, nothing would be best. We reduce the weight of the plane by the weight of the air that we pumped out. We can go faster and/or farther on less. Now the problem... First off, we lost part of the volumetric capacity of the aircraft. Second, we played great games with the CG. Third, by having to seal the area, we increased the "empty" weight some (even if we maintain 1 atmosphere by pumping back in helium). Fourth, we got only minimal improvements... maybe a few pounds savings. That last is the big problem. If we want REAL weight savings we have to increase the volume. That's called a blimp, and to get useful weight savings it must be BIG BIG BIG. Now we have a Bonanza that weighs 100 pounds ... but it's 400 feet long and 100 feet across. And NOW we have to add back in the parasitic drag that all this increased wetted area generates, and now we are down to 35 knots TAS at full power. ----------------------------------------------- James M. Knox TriSoft ph 512-385-0316 1109-A Shady Lane fax 512-366-4331 Austin, Tx 78721 ----------------------------------------------- |
![]() "James M. Knox" wrote in message ... "Louis L. Perley III" wrote in : That last is the big problem. If we want REAL weight savings we have to increase the volume. That's called a blimp, and to get useful weight savings it must be BIG BIG BIG. Now we have a Bonanza that weighs 100 pounds ... but it's 400 feet long and 100 feet across. And NOW we have to add back in the parasitic drag that all this increased wetted area generates, and now we are down to 35 knots TAS at full power. Since it is a glider, it does save the weight of fuel. |
"C J Campbell" wrote in
: Since it is a glider, it does save the weight of fuel. Didn't notice the "and glide down" part until you pointed it out. Okay... so change the above to reflect an aircraft with an engine of 1G thrust rating. G ----------------------------------------------- James M. Knox TriSoft ph 512-385-0316 1109-A Shady Lane fax 512-366-4331 Austin, Tx 78721 ----------------------------------------------- |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
Best Home Base Work | Reynard | Owning | 0 | November 9th 04 04:37 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
Highest-Ranking Black Air Force General Credits Success to Hard Work | Otis Willie | Military Aviation | 0 | February 10th 04 11:06 PM |
Ford V-6 engine work | Corky Scott | Home Built | 19 | August 21st 03 12:04 PM |
