when does a "remain clear" instruction end?
Old March 1st 04, 06:07 AM
Steven P. McNicoll
"Michael Houghton" wrote in message
The ATC handbook (7110.65) includes:
7-8-4. ESTABLISHING TWO-WAY COMMUNICATIONS
Class C service requires pilots to establish two-way radio
communications before entering Class C airspace. If the controller
responds to a radio call with, "(a/c call sign) standby," radio
communications have been established and the pilot can enter Class C
airspace. If workload or traffic conditions prevent immediate provision
of Class C services, inform the pilot to remain outside Class C
airspace until conditions permit the services to be provided.
Thus, the sequence:
N1234: Podunk tower, N1234...rest of stuff in initial callup
Podunk: N1234, remain outside Charlie airspace and standby.
Podunk: N1234, standby.
authorized entry.
What led you to believe the phrase "Stand by" means "authorization to enter
Class C airspace is now granted"?
The second exchange did not instruct the pilot to
remain clear.
The second exchange included no instruction at all, the instruction to
remain outside Class C airspace was not altered in any way.
Steve has insisted the contrary,
Sure, that's just simple logic.
and even claimed to
be a controller working Class C airspace, and claimed to reference
7110.65. I quote what I found on the FAA website. Steve has declined
to rebut with actual citations. His sudden silence on this matter
would seem to be a concession that perhaps he misspoke.
Nope, Steve didn't misspeak. Steve is exactly correct.
7110.65, the order prescribing air traffic control procedures and
phraseology for use by persons providing air traffic control services,
offers no special phraseology for the (hypothetical) instruction Steve
insists must be given.
There are many things that FAAO 7110.65 does not say. For example, it does
not say that "stand by" or "radar contact" authorizes entry for an aircraft
that had previously been instructed to remain outside Class C airspace. Nor
does it say that not repeating the instruction to remain outside in every
subsequent exchange authorizes entry. Why do you suppose that is?
Old March 1st 04, 08:51 AM
Peter
Thus, the sequence:
authorized entry.
Not the "Stand by," but the "N1234, standby." And what might lead someone
to believe that is the direct quote from 7110.65, Sect. 7-8-4 above:
"If the controller responds to a radio call with, '(a/c call sign)
standby,' radio communications have been established and the pilot can
enter Class C airspace."
It also specifies that if the controller feels conditions at that time are
such that the aircraft should not enter Class C space he is to explicitly
state:
"PHRASEOLOGY-
(A/c call sign) REMAIN OUTSIDE CHARLIE AIRSPACE AND STANDBY."
So based on my reading of the 7110.65 handbook it seems clear that if the
controller responds to a radio call with the a/c call sign but without the
explicit statement to "remain outside charlie airspace" then he has allowed
the pilot to proceed through the Class C airspace.
Old March 1st 04, 01:00 PM
Steven P. McNicoll
"Peter" wrote in message
news:bQC0c.155274$uV3.704538@attbi_s51...
Did you miss that the controller had already instructed N1234 to remain
outside Charlie airspace?
Yes, but communications had already been established in this case. Once
you've been instructed to remain outside of Class C airspace you must
receive specific instruction that authorizes entry.
state:
"PHRASEOLOGY-
STANDBY."
Yes, and in this case the aircraft was instructed to remain outside when
communications was established.
the controller responds to a radio call with the a/c call sign but without
the explicit statement to "remain outside charlie airspace" then he has
allowed the pilot to proceed through the Class C airspace.
Then you did not understand what you read.
Old March 1st 04, 01:42 PM
Travis Marlatte
news
Not exactly specific instructions. Since there is no such thing as a
clearance into class C airspace, we'll use the documented method which is to
"establish two-way radio communication." Something like "N1234, state your
intentions" from the controller will do.
are
explicitly
state:
"PHRASEOLOGY-
STANDBY."
And then, when the controller has time to deal it, he calls up and says
"(A/c call sign) squawk 0541" or "(A/c call sign) where were you going?" or
any other question or piece of information with the aircraft's tail number
in it. Having heard this and responded, the pilot has authority to enter the
class C.
without
Steven, I have a lot of respect for your opinion but I am having trouble
with your insistance that this is a cut and dried issue. You, me, and others
are quoting the same pieces of the regs and drawing opposite conclusions. It
is a simple question but the answer is just not clear from the regs.
Your responses that indicate that we are unable to interpret the regs
correctly or that we are not able to understand simple logic does not help
make your case. This has been a healthy debate between people who care
deeply about doing the right thing. Belittling our intelligence has no place
here.
None of the text quoted clearly supports your case - nor mine. Your claims
that simple logic dictates that an explicit clearance is required after a
"remain clear" has been issued are not sufficient.
I believe that you are an experienced controller. I believe that you will do
your job to the best of your ability. I hope that you will have patience
with me, if I ever approach your airspace and ask for clarification before
entering.
Travis
Old March 1st 04, 01:46 PM
Michael Houghton
Howdy!
Thanksfully, Steve left in enough context to make sense of his
nonsense reply.
In article k.net,
Thus, the sequence:
authorized entry.
Plain English comprehension.
7110.65P 7-8-4 says "If the controller responds to a radio call with, "(a/c
call sign) standby," radio communications have been established and the pilot
can enter Class C airspace." In my hypothetical sequence, N1234 made a radio
call and the controller responded using the specific exemplar provided in
the order. The phrase "...and the pilot can enter Class C airspace" is the
key. I'm astonished that you have a problem understanding this, given your
claim to be a controller.
remain clear.
No, it merely served to establish communications in a manner consistent
with FAAO 7110.65P and FAR 91.130(c)1 and the AIM.
and even claimed to
Steve still doesn't offer citations supporting his specific contention
that a "remain clear" instruction, once given, lasts until it is
explicitly countermanded, despite a complete absence of phraseology to
accomplish this in FAAO 7110.65.
Because what it actually says doesn't mean what you keep insisting it means.
yours,
Michael
Michael and MJ Houghton | Herveus d'Ormonde and Megan O'Donnelly
| White Wolf and the Phoenix
Bowie, MD, USA | Tablet and Inkle bands, and other stuff
http://www.radix.net/~herveus/
Mountain flying instruction: McCall, Idaho, Colorado too! [email protected] General Aviation 0 March 26th 04 11:24 PM
Windshields - tint or clear? Roger Long Piloting 7 February 10th 04 02:41 AM
Is a BFR instruction? Roger Long Piloting 11 December 11th 03 09:58 PM
