"Joe Morris" wrote in message
... "Jay Honeck" writes: The pilot survived, right? His health is fine. His career, I sadly suspect, is not. A comment from one of the ASF people at a CFIRC I was at over the past weekend was that he is now flying a desk at the Pentagon. The same man stated that the problem was that the pilot had become too comfortable with practicing the maneuver at his home base, which was about 800 (+/-; I don't recall the exact number) feet lower than the airfield at which the accident occurred. At the accident location he set up the split-S so that the top was at the proper altitude MSL -- at his home base, meaning that the entire maneuver was executed 800 feet lower than it should have been. I have *no* military jet experience, but especially for airshows I'm somewhat surprised that there isn't an altimeter set to QFE to serve as a sanity check against exactly this sort of problem. Joe Morris Newbie ignorance: What does QFE stand for? Jay Beckman Chandler, AZ Student Pilot 3.2 Hrs ... Nowhere to go but up? |
![]() "Jay Beckman" wrote in message news:UU31c.12459$id3.7043@fed1read01... What does QFE stand for? QFE is the altimeter setting that will cause the instrument to read zero at the field elevation. It's used a lot in relatively low lying places (like the UK). If you've got some real elevations you run out little numbers in the altimeter to dry to get the proper QFE in there. |
Jay
QFE QFE is a Q code used by pilots and air traffic control to refer to the current air pressure which will calibrate the pilots altimeter to give actual height above the ground at a particular airfield. Sometimes it's easier to go to Google and type the word or phrase in to get an answer vs asking the group and waiting around for an answer G Big John On Tue, 2 Mar 2004 10:56:21 -0700, "Jay Beckman" wrote: ----clip---- Newbie ignorance: What does QFE stand for? Jay Beckman Chandler, AZ Student Pilot 3.2 Hrs ... Nowhere to go but up? Jay. Remember what goes up must come down (hopefully under control) G |
Jay
Sometimes it's easier to go to Google and type the word or phrase in to get an answer vs asking the group and waiting around for an answer G Thanks, Big John -- but it wasn't me that was doing the asking! -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
"Jay Honeck" wrote in message
news:dY71c.462737$na.1096169@attbi_s04... Jay Sometimes it's easier to go to Google and type the word or phrase in to get an answer vs asking the group and waiting around for an answer G Thanks, Big John -- but it wasn't me that was doing the asking! -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" I think he meant me... The "other" Jay ;o) Jay Beckman Student Pilot - KCHD 3.2 Hrs ... Nowhere to go but up! |
The "other" Jay Whoops! Sorry, Jay! ;-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
news:nj81c.25354$ko6.219040@attbi_s02... I think he meant me... The "other" Jay Whoops! Sorry, Jay! ;-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" Guess you and I will have to stick with full "N" numbers...no abbreviations! G Jay (Beckman) |
![]() "Jay Beckman" wrote in message news:Om81c.12503$id3.73@fed1read01... "Jay Honeck" wrote in message news:nj81c.25354$ko6.219040@attbi_s02... I think he meant me... The "other" Jay Whoops! Sorry, Jay! ;-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" Guess you and I will have to stick with full "N" numbers...no abbreviations! Jay B, In the UK Q codes are used all the time. We set QNH airfield elevation ie above sea level when we are going cross country and set QFE when either working the pattern or arriving to a pattern so that on landing the altimeter reads zero. The normal form of joining in the UK is an overhead join usually at 1000' above the centre of the field with a descent on the dead side aiming to be at pattern height as you cross the upwind end of the runway. Makes for an exciting time when you hear a load of aircraft "in the overhead" sg We also use QDM magnetic bearing to a station QDR bearing from a station when doing a VDF letdown and then QGH, which is heading to steer accompanied by decent instructions from the controller. |
![]() "Jay Honeck" wrote in message news:nj81c.25354$ko6.219040@attbi_s02... I think he meant me... The "other" Jay Whoops! Sorry, Jay! "You can call me Jay, or you can call me...." |
"Jay Beckman" writes:
"Jay Honeck" wrote: Jay Sometimes it's easier to go to Google and type the word or phrase in to get an answer vs asking the group and waiting around for an answer Thanks, Big John -- but it wasn't me that was doing the asking! I think he meant me... The "other" Jay Jay Beckman Student Pilot - KCHD 3.2 Hrs ... Nowhere to go but up! ....and "QFE" by itself as a Google search yields 50,000+ hits, starting with "Quad Fast Ethernet". grin Adding "altimeter" to the search brings up what you need. But as a student pilot, please recall that the most stupid question is the one that you don't ask. If there's something about flying that you don't understand, it's far better to ask it while sitting in front of a monitor at home than to realize while on short final that you need the answer before landing... And while definitions of "QFE" found on Google will probably be correct, there are issues where a search on Google will return conflicting responses. (surprised?) Ask the questions here and you might also get conflicting responses, but you'll also get a discussion as other posters offer arguments for or against one of the answers, giving you some ideas about what to ask your instructor in a face-to-face discussion. And welcome to the ranks of aviation! Joe Morris |
Great shot of the Thunderbird F-16 Ejection | Jay Honeck | Piloting | 51 | February 3rd 04 10:31 PM |
Thunderbird pilot found at fault in Mountain Home AFB crash | Ditch | Military Aviation | 5 | January 27th 04 01:32 AM |
Sunday's Crash in LI Sound | Marco Leon | Piloting | 0 | November 5th 03 04:34 PM |
Thunderbird crash photos | mowkie | Military Aviation | 0 | October 21st 03 04:49 PM |
Thunderbird crash today | John Doe | Military Aviation | 12 | September 16th 03 05:56 AM |
