Instrument rating??
Old March 10th 04, 04:46 PM
Mark Astley
"Michael" wrote in message
om...
"Steven Barnes" wrote
snip
Even so, once I get the rating, I'm betting my ifr minimums will still
be
around the 2k agl mark (2-3 miles visibility).
In that case, you would benefit far more from some competent
instruction in how to fly marginal VFR than from an instrument rating.
Just my opinion as a practicing instrument instructor...
I wonder if minimums in this case are being misinterpreted. For me, the
reason for a 2k minimum (and at least 1 mile visibility) is not because I
don't feel comfortable shooting an ILS down to 200', it's because I fly a
single engine plane and I want an out if the engine decides to take the day
off. If I'm at least within gliding distance of higher ceilings, I know I
can break out and have a chance to find a place to land (side note: there's
a pretty good article in a recent IFR about practicing engine out under the
hood). I see this as conservative risk management (maybe more conservative
than others), not a lack of proficiency. By the same reasoning, regardless
of weather, I think twice about flying over mountains if something will
prevent me from getting decent altitude. I also don't fly at night (other
than the minimum that was required for the PP). As I gain experience, I may
lower my minimums to 1k, but I can't see going much lower than that, at
least not in my current plane.
What skills would a marginal VFR pilot need that they couldn't get from IFR
training? Even under IFR you may find yourself in marginal VFR conditions,
and you still have the responsibility to see and avoid, know what the
weather's doing, have as many outs as you think you need, etc. Or is it
that IFR training assumes these skills are already well developed?
mark
Old March 10th 04, 05:36 PM
Teacherjh
training?
Pilotage. Ground reference maneuvers. Basic attitude flying. VFR chart
interpretation (wrt low altitude rubbernecking). These are the skills you need
for low level marginal vfr flight.
(for Email, make the obvious changes in my address)
Old March 10th 04, 08:56 PM
Mark Astley
"Teacherjh" wrote in message
IFR
training?
I concede that IFR training may not entail these subjects (except for
attitude flying and possibly ground reference), but you definitely need the
same skills, specifically:
Pilotage.
Better know how to do this even under IFR. Electrical systems don't care
whether you filed or not.
You could argue that "circle to land" requires similar skills, but I won't
make a fuss on this one.
This is DEFINITELY covered under IFR training.
VFR chart
Most CFIIs teach using both VFR and IFR charts in case Murphy shows up. I
guess the tacit assumption is that you already know how to read a VFR chart
and can recognize things that might get you in trouble in an emergency.
Old March 11th 04, 12:33 AM
Teacherjh
same skills...
Yes, you need all those skills (and others) for all flying. You may not use
them all on every flight, but you need them in your toolbox. But the question
is "...couldn't get from IFR training?" by which I infer "is specifically
taught in IFR training". Low altitude circle to land is NOT taught in the IFR
training I got, except once when I asked to do a complete low circling approach
and land. It was an eye opener.
IFR flight training is primarily about flying solely with reference to
instruments, and working in the system. Some weather may be covered.
Jose
Old March 12th 04, 03:21 PM
Michael
I did a night circle to land with my instructor about a month ago (vfr,
under the hood). I can honestly say, I didn't like it. Learned alot, though.
He had always talked about how dangerous it can be and after doing one, even
if it was only simulated, was a big eye opener. Things just look all kinds
of wrong. :-)
Tell me, did you like power-on stalls the first time you did them?
Spins? Canyon turns? Landing on very short obstructed strips?
In my opinion, circling maneuvers are not unacceptably dangerous, but
to a greater extent than normal flying they are quite unforgiving of
poor technique. In other words, there is more opportunity to screw up
and less opportunity to correct the screwups. Some people choose not
to do them, and this is their right - but it does reduce the utility
of the rating.
Like any other maneuver, this one can be taught. It's not something
that can be taught on paper - it requires a combination of ground and
flight training. The airlines don't do it.
The reason airlines don't do it is simple - when they moved all their
training to simulators rather than the real airplane - which, despite
anything they tell you, was for reasons of cost more than anything -
they eliminated from their operation anything that could not
effectively be trained in a sim of that era. Sims of that era did not
provide adequate visual and somatic cues for training in circling
approaches.
So I guess my bottom line is this - with proper training, the maneuver
will go from looking very wrong to just looking demanding. I hate to
say your training was improper, but tell me this:
Did you discuss how to select a runway and a circling pattern in
advance?
Did you discuss go-ahead points - meaning a point beyond which even if
you saw the runway you couldn't effectively land on it?
Did you discuss how instrument and visual references are combined to
accomplish the maneuver?
Just as a benchmark, I consider 45 minutes of ground training about
the minimum before going up for the first circling approach - and that
assumes the student has already read the regs and understands about
categories of aircraft, circling vs. straight-in mins, allowable
distance from the runway, etc. It's 45 minutes of just discussing how
to perform the maneuver.
Michael
Old March 11th 04, 03:29 PM
Michael
off.
That's actually quite sensible. My point is that if you're goint to
stick to those minimums, you woud probably be safer flying that
weather VFR under the bottom rather than IFR. It's not necessarily
easier - but with the right training, I think it's safer. I've
snipped the rest of what you wrote, but I do very much agree with it.
I take a pretty dim view of single engine IFR over mountains, or with
ceilings of less than 1000 ft - not because I'd never do it, but
because I HAVE done it and never really felt good about it. In the
end, I wound up with a twin.
training?
Low level navigation and planning, mostly. Planning a route to be
flown at low level is a lot different when you have to follow rivers,
roads, and railroads for obstruction clearance and navigation. The
available cues under a 1000 ft ceiling are a lot different than they
are at higher altitudes, and mistakes can be deadly. If you can't
effectively do an impromptu visual diversion at low altitude and in
low vis, you lack essential safety skills for low altitude VFR.
The emergency procedures are different too. You have to be prepared
to make a precautionary off-airport landing with power, and that means
practice landings on soft and/or rough fields, training in field
selection, etc. Uphill or into the wind? Cow pasture or horse
pasture? Newly ploughed or newly harvested? These are all major
issues.
Michael
Old March 12th 04, 08:00 AM
Thomas Borchert
Michael,
Serious question: What's the basis of that dim view (apart from the
need to rationalize having a twin g)? I just don't see it reflected
in accident numbers, but maybe I am missing something.
Thomas Borchert (EDDH)
Instrument Checkride passed (Long) Paul Folbrecht Instrument Flight Rules 10 February 11th 05 02:41 AM
Instrument Rating Checkride PASSED (Very Long) Alan Pendley Instrument Flight Rules 24 December 16th 04 02:16 PM
Tips on Getting Your Instrument Rating Sooner and at Lower Cost Fred Instrument Flight Rules 21 October 19th 04 07:31 AM
Logging approaches Ron Garrison Instrument Flight Rules 109 March 2nd 04 05:54 PM
