![]() Andrew Gideon wrote: G.R. Patterson III wrote: Even if this is not the case, if you ask a CFI why he recommends a particular course of action, the answer frequently is that you need to get in the habit of doing whatever 'cause you need to do it that way "when you upgrade to higher performance aircraft". Sometimes, though, that's the right answer. Only if you are going to move to a different aircraft soon. If not then it's a bunch of BS. |
![]() Newps wrote: Only if you are going to move to a different aircraft soon. If not then it's a bunch of BS. One of the advantages of flying a Maule is that no CFI criticizes you for raising the flaps on the runway. George Patterson Battle, n; A method of untying with the teeth a political knot that would not yield to the tongue. |
On Mon, 15 Mar 2004 15:51:27 GMT, "G.R. Patterson III"
wrote: Newps wrote: Only if you are going to move to a different aircraft soon. If not then it's a bunch of BS. One of the advantages of flying a Maule is that no CFI criticizes you for raising the flaps on the runway. George Patterson Hmm, what's wrong with flaps up on the runway? That's the way I was taught to land a Cessna 172, touch down, flaps up. I can see how it might make for the possibility of retracting the gear instead of the flaps if you have retractible gear and the levers are both located near each other, but fixed gear? What could be the harm? Thanks, Corky Scott |
![]() Corky Scott wrote: I can see how it might make for the possibility of retracting the gear instead of the flaps if you have retractible gear and the levers are both located near each other, but fixed gear? What could be the harm? To quote various CFIs I encountered when I flew Cessnas, "because there's too much risk of hitting the gear up by mistake when you upgrade to higher performance aircraft". A poster rec.aviation.something last year claimed that there's even an examiner out there who will fail you if you raise the flaps in a 172 while still on the runway. I agree with you, however. I feel you should fly the plane you're in at the moment; not one that you might be able to buy sometime in future. George Patterson Battle, n; A method of untying with the teeth a political knot that would not yield to the tongue. |
On Tue, 16 Mar 2004 00:56:30 GMT, "G.R. Patterson III"
wrote: Corky Scott wrote: I can see how it might make for the possibility of retracting the gear instead of the flaps if you have retractible gear and the levers are both located near each other, but fixed gear? What could be the harm? To quote various CFIs I encountered when I flew Cessnas, "because there's too much risk of hitting the gear up by mistake when you upgrade to higher performance aircraft". A poster rec.aviation.something last year claimed that there's even an examiner out there who will fail you if you raise the flaps in a 172 while still on the runway. I agree with you, however. I feel you should fly the plane you're in at the moment; not one that you might be able to buy sometime in future. George Patterson Battle, n; A method of untying with the teeth a political knot that would not yield to the tongue. Well that makes sense, although failing someone for innocently following the procedures he was taught seems overly harsh. A friend of mine just acquired a V tailed Bonanza, and while sitting in the cockpit the other day I noticed that both the flaps and gear handles are not far from each other, and while the handles are slightly differently shaped, they are both the same color and are at the same height. So one is as easy to grab as the other. In addition, this Bonanza has the dual yokes option, and in this case it means a cross bar that blocks the lower part of the instrument panel from sight. So it would pay to be very careful about grabbing the gear or flap handles in this airplane. I chose to put the flap handle of my homebuilt on the ceiling, so that when the flaps are down, so is the handle. The gear is fixed so raising the flaps upon touchdown will become a normal part of landing. Corky Scott |
