Richard Riley wrote in message . ..
On 16 May 2004 18:22:21 -0700, (Paul Lee) wrote: :This was inspite of the fact that the touchdown speed is 90+ :mph. Oh, sweet Jesus, I hope you're kidding. What empty weight and CG range are you running? Don't think you are informed about canards - especially faster ones. And there is no need to trivialize/misuse Jesus name, it is revered by me and many others. Paul Lee. |
Paul Lee wrote:
Don't think you are informed about canards - especially faster ones. If you'd care to place a wager on Richard 'Renaissance' Riley's knowlege of canards a good portion of the newsgroup would probably take you up on it g So, like he asked, at what weight do you use a *touchdown* speed in excess of 90 knots? Heck, what's your tire speed? That's pretty fast for a well-designed GA canard unless it's pretty freakin' heavy. Dave 'sssssmokin' Hyde |
............. The difference between a 75 mph touchdown and a 90+ mph touchdown is significant. It's a 44% + increase in your momentum. Its a 44% increase in KE, not momentum (20%). But so what? Both momentum and KE are relative only to other objects that shouldn't be on the runway anyway. Turboprops, jets, have higher touchdown speeds. ... I know the Matco W50L's are good, but do you want to get rid of that much of the margin? You mean brake wear? Typically canard flyers let it roll down the runway to save brakes. The lighter vari-ez would have less problem with stopping distance - is that the canard that you fly? Low speed handling is significantly improved by trailing edge fences, you may want to look into them. http://www.lsecorp.com/KlausInfo/Flowfence.htm They also have a problem with low speed roll control which is eliminated with the higher speed touchdown/takeoff - which also eliminates prop torque issues on takeoff. Even in a conventional planes with no flaps, you land more stable at higher landing speeds - a little more runway. BTW Cozy Mark IV is about 200 lbs lighter than SQ2000. |
Paul Lee wrote...
Its a 44% increase in KE, not momentum (20%). But so what? Both momentum and KE are relative only to other objects that shouldn't be on the runway anyway. Silly me, and here I thought I higher KE at touchdown would result in longer landing distances - a 44% increase a *much* longer rollout. You mean brake wear? Typically canard flyers let it roll down the runway to save brakes. Greater than 90 knots and no braking on rollout? What's you're minimum field length? Even in a conventional planes with no flaps, you land more stable at higher landing speeds - a little more runway. So do you pad your approach speed to come up with the 90+ figure or is that the designer's recommendation? It strikes me as obscenely fast, even compared to other canards. Dave 'FBAW' Hyde |
Hmmmmm... I was answering Richard and now I get Dave...???
"nauga" wrote in message nk.net... Paul Lee wrote... Its a 44% increase in KE, not momentum (20%). But so what? Both momentum and KE are relative only to other objects that shouldn't be on the runway anyway. Silly me, and here I thought I higher KE at touchdown would result in longer landing distances - a 44% increase a *much* longer rollout. You mean brake wear? Typically canard flyers let it roll down the runway to save brakes. Greater than 90 knots and no braking on rollout? What's you're minimum field length? Even in a conventional planes with no flaps, you land more stable at higher landing speeds - a little more runway. So do you pad your approach speed to come up with the 90+ figure or is that the designer's recommendation? It strikes me as obscenely fast, even compared to other canards. Dave 'FBAW' Hyde |
On 18 May 2004 07:15:20 -0700, (Paul Lee)
wrote: :Richard Riley wrote in message . .. :............. : The difference between a 75 mph touchdown and a 90+ mph touchdown is : significant. It's a 44% + increase in your momentum. : :Its a 44% increase in KE, not momentum (20%). OK, let's be precise. On landing you intend to have 44% (plus) more kinetic energy than other airplanes with exactly the same weight, wing and engine. That's going to result in a 44% (plus) longer stopping distance (as the brakes get hot, they also become less effective, so it's not a 1:1 ratio). But that's once you're able to actually put it on the runway. The high L/D that the canards enjoy means they tend to float a lot down the runway, so when you're landing fast it's very hard to touch down close to the numbers. Your retract gear will help that, somewhat, by making the aircraft dirtier in the pattern, and easier to slow down, than something with fixed and faired gear with wheel pants. In any event, you will be landing much faster and longer than other aircraft with identical performance. :But so what? Both :momentum and KE are relative only to other objects that shouldn't be ![]() And, as everyone knows, nothing ever goes wrong. There is never anything on the runway that shouldn't be there. You never have to land on a shorter runway than you intend, and you never land at higher than expected density altitude. :Turboprops, jets, have higher touchdown speeds. Turboprops and jets have longer runway requirements, greater crash protection requirements, more frequent inspections, and higher pilot requirements. Most require 2 pilots. Having the landing requirements of a jet, and the maintenance requirements and speed of a piston prop, is not a good compromise. : :... I know the : Matco W50L's are good, but do you want to get rid of that much of the : margin? : :You mean brake wear? Typically canard flyers let it roll down the runway :to save brakes. No, I mean brake fade. The W50L disk is good for about 190k ft/lbs each. The total energy that can be absorbed by a brake disk is dependent on it's material and mass. Your airplane at full gross weight and 95 mph has 340k ft/lbs of energy. So you are down under 10% for your safety margin. Don't land at Denver in the summer. :The lighter vari-ez would have less problem :with stopping distance - is that the canard that you fly? It's a derivative of the Vari-Eze (proper spelling, we must be precise, after all) but it's a little faster. I'll make you a deal. When you get your plane done, I'll race you for pink slips, or a bottle of 30 year old single malt. I'll even spot you extra 100 lbs. in payload. : : Low speed handling is significantly improved by trailing edge fences, : you may want to look into them. : http://www.lsecorp.com/KlausInfo/Flowfence.htm : :They also have a problem with low speed roll control which is eliminated :with the higher speed touchdown/takeoff - which also eliminates prop torque :issues on takeoff. At 200 hp, you won't have any issue with prop torque. And I've never had a significant problem with low speed control, provided CG is within the envelope. Just a touch of adverse yaw, below 110 kts. Lower winglets (even small ones) help that significantly by damming off the high pressure at the outboard end. Filleting the wing TE back to the winglet TE with a pen-nib fairing (you can see it on the Delaminator, at SnF or Osh), the standard vortalons, and Klaus' TE fences all help lower the minimum airspeed. : :Even in a conventional planes with no flaps, you land more :stable at higher landing speeds - a little more runway. If you are landing on 8000 feet, or even 5000, it's not a problem. Try putting in on 2500 over some trees at the end of the runway, it's a problem. : :BTW Cozy Mark IV is about 200 lbs lighter than SQ2000. Now that's strange, isn't it. Empty weight on a Cozy Mk 4 is generally around 1100-1200 with a 2050 lb gross. On the Speed Queen, you're looking at close to the same empty - 1100-1250. That makes sense, its the same wing, the same engine, the same size fuselage, the same materials. You save a little weight with vacuum bagging (not as much as you'd think, but some) and loose a little with the retract gear. (And you gain a little in drag reduction with the retract gear, but again, not as much as you might think. Fairing the legs and putting a good set of wheel pants on the gear will eliminate 90% of the drag of the gear. Retracting them gets rid of that last 10% - in exchange for the weight and complexity of a retract system, increased insurance rates and pilot requirements, a less forgiving failure mode and more maintenance. There are a number of airplanes that fly slower with a retractable gear than with a well faired gear.) So, with the same empty weight, cabin dimensions, wing and engine, if you have the same fuel load, baggage and passenger weight, the two airplanes will take off, climb, cruise and land pretty much the same. But the max gross weight is different - 2250 listed by Stan for the Speed Queen. That's 10% more than the Cozy. Is it because the Speed Queen is so much stronger than the Cozy? That seems unlikely, composite aircraft - especially fiberglass aircraft - are generally engineered to minimum stiffness requirements, rather than failure loads. As a result, they usually end up much stronger than they need to be. Their gross weights are dictated by performance, rather than ultimate load. So, basically, Stan is willing to accept less takeoff, climb, cruise and landing performance at full gross weight than Nat, in exchange for a higher useful load. But there seems to be something wrong there, too. The KLS web site doesn't seem to exist any more, but the old numbers I have in my files show a sea level max gross climb rate of 2200 FPM. Since the Cozy, with it's lighter max weight, only claims 1200 FPM at 2050 gross, the Speed Queen number seems optimistic to me. The same is true on the top end - SQ claims 258 MPH Vmax, Cozy 4 claims 220 mph and demonstrates (CAFE test) 209.8 mph at 1668 lb, 29.2", 2691 rpm, 12.9 gph. Can it be that the SQ fuselage shape is so superior to the Cozy that it's flying 25% faster and climbing almost twice as fast? It seems unlikely. But all the power performance numbers aside, it's simply should not be necessary to land at 90+ mph. Airplanes with exactly the same flying surfaces and weight touch down at 75-80. When I say exactly, I mean exactly - to the fraction of an inch in planform, with the same templates, with the same modified Eppler airfoil on the mains, and the same Roncz 1145 MS on the canard. (BTW, the MS stands for Mike and Sally Mellville, no matter what you've been told) Landing that fast increases risk, limits the airports you can land at, and increases wear. If there is an accident of any kind, it's significantly worse. The same accident that's survivable at 75 MPH and 1 degree impact angle is not remotely survivable at 90 mph and 1 degree. That's the biggest reason to fly the left hand part of the envelope, as well as the right. |
Thanks for taking time to deal with more detail. Although
you included many more issues than I raised. And I am sure the KE/mv confussion was just a slip of the pen. But let me just clarify some things: Richard Riley wrote in message . .. ................ But there seems to be something wrong there, too. The KLS web site doesn't seem to exist any more, but the old numbers I have in my files show a sea level max gross climb rate of 2200 FPM. Since the Cozy, with it's lighter max weight, only claims 1200 FPM at 2050 gross, the Speed Queen number seems optimistic to me. The same is true on the top end - SQ claims 258 MPH Vmax, Cozy 4 claims 220 mph and demonstrates (CAFE test) 209.8 mph at 1668 lb, 29.2", 2691 rpm, 12.9 gph. ........... KLS website is gone because KLS is in process of changing name. KLS was a partnership and one of the partners left. The new name is Advanced Composite Design, Inc. KLS has also just finished developing a new desing of a large plane (tested and flying). Thats explained at my website http://www.abri.com/sq2000 I just came back from SQ2000 factory training. I haven't tried the factory model to Vne. I was mainly interested in take off and landing skills. But Stan indicated he achieves 230mph cruise. But isn't Cozy IV fixed main gear? That would explain some of the difference. Landing that fast increases risk, limits the airports you can land at, and increases wear. ......... True. But in my case we have two 6800 x 150 foot runways. In SQ2000 factory flight training I was instructed to touchdown at 90MPH and did consistently and the bird exhibited no problem behaviour. I am sure that after I get a lot more hours experience like you or Stan, I'll be able to cut the landing speed. If you are around Pierre, SD you are welcome to check out my bird. Interestingly, while on the subject of safety, about 6 weeks ago, the KLS SQ2000 came down in a storm and busted the landing gear. It slid down the runway and into a ditch. No injuries, it did not flip over, and surprisingly the damage was mainly to the landing gear and the prop (toothpicks all over) - very little other damage. |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
