"Jim Fisher" wrote in message et...
wrote in message It may have been invented already by somebody else, and I have not read about it. It has. Submarines use this technology to reduce cavitation and noise. Either way, if I am the first, it is now a public domain invention, for all to use!!! As soon as you come up with a way to offset the added weight and complexity (gotta ad a gear box there somewhere, ya' know) I'm sure you are sitting on a million dollars, Doug. Got for it, buddy! The test prop is a light wood, ultralight prop, 20 inchs shorter than the C-150 prop. It can be bolted to the hub bearing wise. A small inch shaft is used and a pair of normal flange bearings. It should be suitable for flight, and its harmonic is expected to be about 300 rpm. So it should then vibrate again at about 40 rpm ![]() stable in high rpm moving conditions because the power is applied by the air movement and not the shaft! The shorter prop will have the air redirected onto the part of the prop that looks like it is incapable of making wind. The thick near the hub parts. The need for the rather odd twist on the aircraft is vibration. A boat design with the pitch fully carried to the hub will vibrate and fatiuge the wood fibers even. An STC for a C-150 is easy if the weight change is nose down weight. Adding weight to the tail is the hard STC to obtain. Adding a lighter starter, as an STC, is the same type of stability change. Douglas Eagleson Gaithersburg, MD USA |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
What's Wrong with Economics and how can it be Fixed | What's Wrong with Economics and how can it be Fixe | Naval Aviation | 5 | August 21st 04 12:50 AM |
The Internet public meeting on National Air Tour Standards begins Feb. 23 at 9 a.m. | Larry Dighera | Piloting | 0 | February 22nd 04 03:58 PM |
God Honest | Naval Aviation | 2 | July 24th 03 04:45 AM |
