faith in the fuel delivery infrastructure
Old April 1st 04, 06:36 PM
Robert M. Gary
"Chris Hoffmann" wrote in message ...
I'll probably need an airport tour to answer this to my satisfaction, but I
thought it merited a discussion here anyway.
It seems pretty standard that, after an airplane is refueled, you wait 10-15
minutes and resample the fuel to check for contaminants (water). I recently
witnessed a situation where the fuel was checked during preflight, but not
after refueling. The reason given was that at this particular airport, the
fuel supply is replenished/recycled daily, if not more, and so there isn't
time for water, or perhaps *enough* water, to collect in the storage tanks
and end up in an aircraft's fuel tanks.
It could. The truck's tank should be sampled and checked for water
just like the airplane though. It is a good idea to check the fuel
after fueling (I usually skip it during the pre-flight if I'm going to
go get fuel).
-Robert
Replacing fuel cut-off valve with non-a/c part??? Michael Horowitz Owning 46 January 15th 05 10:20 PM
Cessna 172 with Wild Fuel Gauge Needle jls Owning 26 February 20th 04 05:56 AM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
Hot Starting Fuel Injected Engines Peter Duniho Piloting 23 October 18th 03 02:50 AM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
