500 hours!
Old April 3rd 04, 06:15 PM
Peter Duniho
"Philip Sondericker" wrote in message
Okay, so did I solo at 11.3 hours, or did I solo at 12.5 hours?
I don't understand why you need to ask. The phrase "I soloed at x hours"
is equivalent to "I had flown x hours before I flew solo". It's obvious
how many hours you had before you flew solo, and the number sure as heck
isn't 11.3.
Old April 3rd 04, 10:24 PM
Peter Duniho
Hmmm, so you're saying it's a number somewhere between 11.3 and 12.5? So
why
is it that so many people are confidently able to state, "I soloed at
exactly such-and-such hours", when in fact their circumstances were likely
similar to mine?
Let's ignore for the moment the fact that comparing time-to-solo numbers is
dumb anyway, given the vast disparity in the quality of instructors, the
quality of students, and various factors out of either's control (weather,
distance of practice area, other traffic, etc.). I also don't know why it's
hard for you to figure out what the number for you is, but I'll accept that
it is.
In your example, at the point in time at which you were permitted to act as
the solo pilot in command of the airplane, you had already received 11.3
hours of dual prior to that flight, plus another 0.9 hours of dual that
flight. If you add the two numbers, you get 12.2 hours of dual instruction
prior to your solo.
The reason that so many people are confidently able to state "I soloed at
exactly such-and-such hours" is that they have kept an accurate record of
their dual instruction hours up to that point, and they are able to add the
hours together to come up with a single cumulative figure.
If that still doesn't answer your question, please describe as precisely as
you can what part is still confusing, and I'll be happy to try to clarify
the answer.
Pete
Old April 4th 04, 03:11 AM
Philip Sondericker
in article , Peter Duniho at
wrote on 4/3/04 1:24 PM:
why
similar to mine?
it is.
Oh, trust me, I'm not trying to turn this into a "least hours to solo"
competition or anything. It's just that I'm often asked, "How many hours did
you have before you soloed?", and I'd like to give an accurate answer,
that's all.
prior to your solo.
Well, not exactly. You see, at the start of the lesson in question, I
received some dual instruction for an undetermined length of time, then I
soloed for .3 hours, then I received some more dual instruction flying back
to the home airport. Before the lesson I had 11.3 hours, and after it I had
12.5 hours. That's why I don't know exactly how many hours I had prior to
solo.
the answer.
Pete
See above.
Old April 4th 04, 03:58 AM
John Clonts
So
why
likely
similar to mine?
is
(weather,
it's
that
it is.
did
that's all.
as
instruction
prior to your solo.
back
had
solo.
Just say 12 hours and be done with it! Or, "around 10 hours or so"! Or,
"under 15 hours"! Just pick your number, and stick by it!
Cheers,
John Clonts
Temple, Texas
N7NZ
Old April 4th 04, 04:25 AM
Peter Duniho
back
had
solo.
If you don't provide accurate information, you don't get accurate answers.
As for your "undetermined length of time", I guess that's your own fault for
not logging the time. But the rest of us actually keep track of time, and
know when things start and stop.
I don't see how you could know you flew solo for 0.3 hours without knowing
the time at which you started your solo flight and the time at which you
ended it. And if you know when you started your solo flight, you ought to
be able to know when you ended the dual instruction prior to it. But I
guess if you don't know, you just don't know.
The answer to your question regarding how the rest of us know is that we
actually bothered to pay attention. We kept track of the time. In many
cases, the solo flight was done at the home base airport, and after the last
solo landing, the student simply taxied back to parking. So obviously in
that very common case, it would be trivial for someone who knows how much
solo time they had to also know how much dual instruction they had prior.
Bottom line: you say "I'd like to give an accurate answer". The problem in
your case is that you didn't track your time well enough to give an accurate
answer. I don't see how you can resolve the issue now. You have a
fundamental lack of information necessary to do what you want to do, and
unless you figure out a way to recover that information from other sources,
there's nothing you can do about it. Certainly none of us have any way to
figure it out for you.
Pete
Old April 4th 04, 04:45 AM
Philip Sondericker
wrote on 4/3/04 7:25 PM:
back
had
solo.
Pete
Hey, that's cool Pete. I hope I didn't upset you.
Old April 4th 04, 07:43 AM
Peter Duniho
I have no idea how you might have.
I did find your question a bit bizarre, given the obviousness of the answer
(IMHO, of course). But "bizarre" is Usenet's middle name, right?
Old April 4th 04, 11:43 AM
Cub Driver
On Sun, 04 Apr 2004 02:11:00 GMT, Philip Sondericker
And you can be pretty sure that the person who asks that is not
interested in a lecture, or even in an answer with decimal points. For
purposes of the example posted just above, either 10 or 11 hours would
serve just fine. (Or ws it 11 or 12?)
Personally, I had 48, and I was assured that it was not a field
record.
all the best -- Dan Ford
email: (put Cubdriver in subject line)
The Warbird's Forum
www.warbirdforum.com
The Piper Cub Forum www.pipercubforum.com
Viva Bush! blog www.vivabush.org
Career Change - Full-time CFI: Average Flight Hours per year? Peter Gibbons Piloting 22 January 19th 04 12:02 AM
AmeriFlight Crash C J Campbell Piloting 5 December 1st 03 02:13 PM
