![]() "Steven P. McNicoll" wrote in message nk.net... "BTIZ" wrote in message news:vJqbc.69606$1I5.24219@fed1read01... But I did not think he said anything about changing the floor of the airspace for weather, he stated that the lower floor provides transistions for IFR pilots to get close to the airport, and CLEAR OF VFR traffic in marginal weather, that should be remaining in Class G and not Class E where the approach may dump them off. He said; "Those circles aren't to keep VFR pilots safe when the weather is marginal. They are to lower the floor of controlled airspace for the benefit of IFR pilots." Correct. The transition area lowers the floor of controlled airspace. I never said it had anything to do with changing weather conditions. The first sentence was to refute the hypothesis of the original poster. |
![]() "Ron Natalie" wrote in message m... Correct. The transition area lowers the floor of controlled airspace. The floor of controlled airspace is fixed. |
![]() "Steven P. McNicoll" wrote in message ink.net... "Ron Natalie" wrote in message m... Correct. The transition area lowers the floor of controlled airspace. The floor of controlled airspace is fixed. The transition area floor is LOWER than it would be if there were no transition area. It's a local dropping of the controlled airspace floor from 1200 (typically) to 700. Everybody else seems to understand what I'm saying except for you. Stop and try to think about the real issue rather than trying to generate as much confusion as possible. |
![]() "Ron Natalie" wrote in message m... The transition area floor is LOWER than it would be if there were no transition area. It's a local dropping of the controlled airspace floor from 1200 (typically) to 700. Correct. Everybody else seems to understand what I'm saying except for you. Stop and try to think about the real issue rather than trying to generate as much confusion as possible. I understand you didn't intend to imply the floor of controlled airspace varied with weather or type of operation. If you put more thought into your writing you'll generate less confusion. |
"Ron Natalie" wrote in message om...
"Steven P. McNicoll" wrote in message nk.net... "BTIZ" wrote in message news:vJqbc.69606$1I5.24219@fed1read01... But I did not think he said anything about changing the floor of the airspace for weather, he stated that the lower floor provides transistions for IFR pilots to get close to the airport, and CLEAR OF VFR traffic in marginal weather, that should be remaining in Class G and not Class E where the approach may dump them off. He said; "Those circles aren't to keep VFR pilots safe when the weather is marginal. They are to lower the floor of controlled airspace for the benefit of IFR pilots." Correct. The transition area lowers the floor of controlled airspace. I never said it had anything to do with changing weather conditions. The first sentence was to refute the hypothesis of the original poster. As the original poster, the only thing that can even be close to a hypothesis is my suspicion that VFR pilots take advantage of the Class E/G boundary by shooting T&Gs below 700 feet AGL. How does that first sentence "refute" that? And, for the record, the purpose of my post was to find out if anyone actually made use of the information conveyed by the magenta circles, or if most people found them as useless as I do. |
![]() And, for the record, the purpose of my post was to find out if anyone actually made use of the information conveyed by the magenta circles, or if most people found them as useless as I do. Well, I am conscious that if I were ever scud-running home, I would have to get down to an uncomfortable altitude once I got within xx miles of my home airport. That would incline me to land elsewhere, in the unlikely event that I hadn't done so already. That would be making use of the information, wouldn't it? all the best -- Dan Ford email: (put Cubdriver in subject line) The Warbird's Forum www.warbirdforum.com The Piper Cub Forum www.pipercubforum.com Viva Bush! blog www.vivabush.org |
Ice meteors, climate, sceptics | Brian Sandle | General Aviation | 43 | February 24th 04 12:27 AM |
