"Pete Schaefer" wrote in message
news:xMprc.4694$ny.935185@attbi_s53... . . . Unfortunately, air-bags are out of the question for aviation use (for the pilot at least....probably for everyone). Not. See http://www.avweb.com/news/snf2003/184230-1.html - last article, bottom of page. Rich S. |
Air bags are a factory option on some certified planes, including the
Mooney. The bags are built into the seat belts. Frank "Rich S." wrote in message ... "Pete Schaefer" wrote in message news:xMprc.4694$ny.935185@attbi_s53... . . . Unfortunately, air-bags are out of the question for aviation use (for the pilot at least....probably for everyone). Not. See http://www.avweb.com/news/snf2003/184230-1.html - last article, bottom of page. Rich S. |
On Fri, 21 May 2004 15:41:04 -0500, frank wrote:
Air bags are a factory option on some certified planes, including the Mooney. The bags are built into the seat belts. Frank How are these things controlled? Where is the g-switch that triggers them? Do they need electrical power to run the system? I wonder what sort of electrical failures could cause them to fire when they shouldn't? There have been incidents and accidents where debris in wiring bundles has shorted a live wire to another wire, thus sending voltage where it wasn't meant to go. This could potentially cause one of those air bags to fire when it shouldn't. I wonder if the air bag would push forward on the yoke if it fired in flight? If this happened at low altitude, or a high enough airspeed, could it cause an accident? If so, could installing one of these air bags actually reduce the level of safety? Of is the perception of safety more important than actual safety? Just wondering. -- Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://go.phpwebhosting.com/~khorton/rv8/ e-mail: khorton02(_at_)rogers(_dot_)com |
![]() "Kevin Horton" wrote in message news ![]() On Fri, 21 May 2004 15:41:04 -0500, frank wrote: I wonder if the air bag would push forward on the yoke if it fired in flight? If this happened at low altitude, or a high enough airspeed, could it cause an accident? If so, could installing one of these air bags actually reduce the level of safety? Of is the perception of safety more important than actual safety? There are many "safety" devices, including airbags, safety belts, helmets etc. that can occasionally backfire in a way to cause a death that might otherwise not happen. The important thing is that after all is said and done, the pile of people killed by the device must be much smaller than the pile of people that would otherwise be dead without the device. Vaughn |
Vaughn wrote:
"Kevin Horton" wrote in message news ![]() On Fri, 21 May 2004 15:41:04 -0500, frank wrote: I wonder if the air bag would push forward on the yoke if it fired in flight? If this happened at low altitude, or a high enough airspeed, could it cause an accident? If so, could installing one of these air bags actually reduce the level of safety? Of is the perception of safety more important than actual safety? There are many "safety" devices, including airbags, safety belts, helmets etc. that can occasionally backfire in a way to cause a death that might otherwise not happen. The important thing is that after all is said and done, the pile of people killed by the device must be much smaller than the pile of people that would otherwise be dead without the device. Vaughn Perhaps less obvious, but just as important is how HARD that airbag hits you when it goes off. The TV always shows it in slow motion - so you can see it happening. In reality, that sucker is gonna slap you silly, if not completely out. Richard |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
