![]() "G.R. Patterson III" wrote in message ... snip The data plate was located inside the aircraft until the early '90s. Then the feds passed two regulations; one required that all aircraft have 12" high N-numbers and the other required an identification plate be added at the tail. These were quickly ammended to allow aircraft with smaller numbers to retain them until the next paint job, allow some other aircraft (mainly antiques) to retain the smaller numbers, and to allow the registration info to be painted on instead of having a plate if the aircraft did not originally come with an exterior plate. George Patterson The 12' numbers are for crossing the ADIZ and/or for aircraft with a cruise speed that is higher than most piston engined aircraft. Here's the FAR (pulled from the Matronics RV List Archives - a very handy source of information): http://www.matronics.com/searching/search.html 45.29 Size of marks. (a) Except as provided in paragraph (f) of this section, each operator of an aircraft shall display marks on the aircraft meeting the size requirements of this section. (b) Height. Except as provided in paragraph (h) of this part, the nationality and registration marks must be of equal height and on - (1) Fixed-wing aircraft, must be at least 12 inches high, except that: (i) An aircraft displaying marks at least 2 inches high before November 1, 1981 and an aircraft manufactured after November 2, 1981, but before January 1, 1983, may display those marks until the aircraft is repainted or the marks are repainted, restored, or changed; (ii) Marks at least 3 inches high may be displayed on a glider; (iii) Marks at least 3 inches high may be displayed on an aircraft for which an experimental certificate has been issued under 21.191(d) or 21.191(g) for operating as an exhibition aircraft or as an amateur-built aircraft when the maximum cruising speed of the aircraft does not exceed 180 knots CAS; and (iv) Marks may be displayed on an exhibition, antique, or other aircraft in accordance with 45.22. (2) Airships, spherical balloons, and nonspherical balloons, must be at least 3 inches high; and (3) Rotorcraft, must be at least 12 inches high, except that rotorcraft displaying before April 18, 1983, marks required by 45.29(b)(3) in effect on April 17, 1983, and rotorcraft manufactured on or after April 18, 1983, but before December 31, 1983, may display those marks until the aircraft is repainted or the marks are repainted, restored, or changed. (c) Width. Characters must be two-thirds as wide as they are high, except the number "1", which must be one-sixth as wide as it is high, and the letters "M" and "W" which may be as wide as they are high. (d) Thickness. Characters must be formed by solid lines one-sixth as thick as the character is high. (e) Spacing. The space between each character may not be less than one-fourth of the character width. (f) If either one of the surfaces authorized for displaying required marks under 45.25 is large enough for display of marks meeting the size requirements of this section and the other is not, full-size marks shall be placed on the larger surface. If neither surface is large enough for full-size marks, marks as large as practicable shall be displayed on the larger of the two surfaces. If any surface authorized to be marked by 45.27 is not large enough for full-size marks, marks as large as practicable shall be placed on the largest of the authorized surfaces. (g) Uniformity. The marks required by this part for fixed-wing aircraft must have the same height, width, thickness, and spacing on both sides of the aircraft. (h) After March 7, 1988, each operator of an aircraft penetrating an ADIZ or DEWIZ shall display on that aircraft temporary or permanent nationality and registration marks at least 12 inches high. Section iii is for you. Unless you intend to fly a ADIZ or DEWIZ then if your cruising speed is 180 KNOTS CAS you can use the 3". Note! Canada doesn't count. KB |
![]() (iv) Marks may be displayed on an exhibition, antique, or other aircraft in accordance with 45.22. Is "antique" a matter of years, and if so how many? all the best -- Dan Ford email: (put Cubdriver in subject line) The Warbird's Forum www.warbirdforum.com The Piper Cub Forum www.pipercubforum.com Viva Bush! blog www.vivabush.org |
![]() Cub Driver wrote: (iv) Marks may be displayed on an exhibition, antique, or other aircraft in accordance with 45.22. Is "antique" a matter of years, and if so how many? Thirty. See 45.22.b. George Patterson This marriage is off to a shaky start. The groom just asked the band to play "Your cheatin' heart", and the bride just requested "Don't come home a'drinkin' with lovin' on your mind". |
I'M GOING TO DIE TODAY. | ArtKramr | Military Aviation | 0 | February 4th 04 09:44 PM |
12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 12th 03 11:01 PM |
"Target for Today" & "Thunderbolt" WWII Double Feature at Zeno'sDrive-In | Zeno | Aerobatics | 0 | August 2nd 03 07:31 PM |
"Target for Today" & "Thunderbolt": An Awesome WWII DoubleFeature at Zeno's Drive-In | zeno | Military Aviation | 0 | July 14th 03 07:31 PM |
The Yankee Lady Flew Today | Tom Huxton | Piloting | 0 | July 11th 03 11:57 PM |
