C172SP engine start with battery switch only?
Old April 11th 04, 10:21 PM
Robert Winn
Default C172SP engine start with battery switch only?
Rented a C172SP (Made in 1999) on 04/10/04 and was told to start the engine
with the battery side of the master switch only on, then turn on the
alternator side after the engine was running. I was told that this was a
new recommendation for all C172SP's. Can someone tell me where to find the
text of this recommendation?
Thanks in advance,
Robert Winn
Old April 11th 04, 11:20 PM
Peter Clark
On Sun, 11 Apr 2004 16:21:45 -0500, "Robert Winn"
It was included in a service bulletin from Cessna regarding some
faulty ACU's in (insert large number of serial numbers here).
SB04-24-01A, Mar 1 04. The temporary start procedure (alternator side
of master off) to be removed from POH once the replacement unit is
installed.
P
Old April 12th 04, 12:14 AM
Mark Klebanoff
On Sun, 11 Apr 2004 22:20:51 UTC, Peter Clark
installed.
P
I've read that we should start all airplanes with a split master
switch that way. Turning on the alternater half of the master
energizes the field windings of the alternator, which just wastes
battery power and heats up the alternator. I've been starting planes
that way for many years now. Once the engire starts I bring the
alternator on line by turning on both halves of the mater switch.
Every Cherokee, Cessna and Bonanza I've been in has a split master,
but as I recall the Mooney 201 and 231's I've flown do not-- it's
either everything on or nothing on.
Old April 12th 04, 12:25 AM
Bob Gardner
It's common sense, when you think about it. With both halves of the switch
ON, the alternator field windings are connected across the battery, creating
a drain in addition to that drawn by the starter...and the alternator can't
make electricity until the engine is rotating anyway. So why keep that load
across the battery? Turn off the alternator side, directing all battery
voltage to the starter, and only then put the alternator field windings into
play.
Bob Gardner
"Robert Winn" wrote in message
engine
Thanks in advance,
Robert Winn
Old April 12th 04, 01:04 AM
Roger Long
By watching the ammeter as you do this, you can verify the charging system
function and confirm that the starter relay has not hung up which can turn
the starter into a generator at higher RPM's and fry parts of the electrical
system and avionics. It also makes for easier starts in cold weather for
the reasons the other posters mention.
When you start you should see negative ammeter deflection and any alternator
warning lights should come on. After the engine is running. bring the
alternator on line and the ammeter should switch over to positive deflection
and taper back to zero within about a minute. The alternator warning lights
should go out. After you have done this a few times in a plane, you'll be
able to spot any change in charging system function quiet easily.
You can even get an insight into battery condition. If you've drained it by
having lights on for your preflight, running flaps ups and down, etc. You'll
see a larger ammeter deflection. If you see that deflection without a
reason, it may mean something is going south in the charging system.
The only reason I have heard not to do this all the time is that the
alternator has a sudden load thrown on it. This may be an issue for
alternators directly driven by expensive gear trains but I think the belt
driven ones have a pretty good shock absorber in the belt.
Roger Long
Robert Winn wrote in message
engine
Thanks in advance,
Robert Winn
Old April 12th 04, 01:06 AM
Peter Duniho
"Bob Gardner" wrote in message
news:_tkec.120289$K91.333719@attbi_s02...
creating
It's worse than that, too. Not only is the battery being used to energize
the alternator field circuit, but having that circuit energized creates drag
on the engine, making the starter work harder.
Pete
Old April 12th 04, 06:05 AM
C J Campbell
engine
Thanks in advance,
This was a service bulletin that applies to Cessna piston singles having to
do with the alternator field breaker popping. Until this SB is fully
complied with you are supposed to start the engine this way. The SB came
with a temporary yellow page that is inserted into the "Normal Procedures"
checklist in the POH, but no revision for the separate checklist.
Mike Pickett tells me that you should only use the battery side of the
switch anyway, especially when using external power. He says starting the
engine on external power with the alternator switch on was what caused my
alternator to burn out several months ago.
Old April 12th 04, 08:32 PM
David Brooks
switch
creating
drag
It makes sense to me, too, but I've always been told to follow the
procedures in the POH. My 172 POH's don't contemplate the split switch
start. Also, I'm concerned that if I change my routine now, I'll be taking
off with a rapidly draining battery one day.
Having said that, I split the switch to do the flaps and lights check early
in the pre-flight.
-- David Brooks
Old April 13th 04, 12:31 AM
Roger Long
Check in the section on operations in cold weather. It will probably refer
to the split switch start there. If you can do it cold weather, and they
don't give a maximum temperature at which it is "permissible" you are in
compliance with the POH.
Of course, if you fly your (at least older) Cessna in strict compliance with
the POH, you'll screw up your engine.
Roger Long
David Brooks wrote in message
switch
creating
energize
drag
early
in the pre-flight.
-- David Brooks
Turbine air start -- too cold? Juan Jimenez Home Built 97 March 14th 05 06:51 PM
Diesel engine Bryan Home Built 41 May 1st 04 07:23 PM
Engine... Overhaul? / Replace? advice please text news Owning 11 February 17th 04 04:44 PM
Objective Engine Discussion Rick Maddy Home Built 26 October 14th 03 04:46 AM
