I can't say that I have tried every prop and engine combination, but I have
never been able to stop a prop without pulling the nose up to an alarming attitude...you can pretty much count on it windmilling. You are experiencing "flat plate drag." In cruise and reduced power descent, the prop is pulling the airplane through the air (duh). As manifold pressure is reduced toward idle, the prop governor flattens the pitch in an attempt to maintain RPM, but when it hits the low pitch stops, that's all there is. If you go all the way to idle, the windmilling prop drives the engine...the crankshaft is turning, the pistons are doing their thing, etc, but no motive force is produced.What you do get is disturbed air over the horizontal stabilizer, reducing its effectiveness. You goal is to set the MAP to where the prop is essentially idling, neither pulling nor creating drag. That will be at about 11 inches in most cases. If you set up a long glide to final, just as a test, play with the manifold pressure and if you have a sensitive butt you will almost feel it when you have pulled the throttle back too far. Bob Gardner "Ed" wrote in message ... I'm fairly new to GA after a 19 year break flying jets. I routinely fly a single engine experimental with a constant speed prop mounted on a Lycoming IO-360. 2 QUESTIONS: 1. What's the proper setup to simulate the way the plane would glide in case of an engine failure? I'm looking for pitch and possibly a manifold pressure number here. 2. It that motor quits, will it still rotate through the flying airspeed envelope or can I expect it to stop rotation (assuming it's not frozen due to a mechanical failure)? In idle, with the prop at flat pitch, it feels too draggy and comes down like a rock. With it at high pitch, it seems to have too optimistic a glide ratio. What's the happy medium? I don't live near a dry lake bed or I'd just shut it down and find out. I have the proper airspeeds for max range and min sink out of the POH but it does not quote any type of glide ratio. Ed |
![]() Bob Gardner wrote: I can't say that I have tried every prop and engine combination, but I have never been able to stop a prop without pulling the nose up to an alarming attitude...you can pretty much count on it windmilling. One of the aviation writers (Schiff, IIRC) did some experiments along those lines. He came to the conclusion that stopping the prop was only productive in terms of improving glide distance if you were more than 6,000' AGL at the time the rubber band broke. You have to get very close to stall speed to get it stopped. He was working with fixed pitch propellors, however. George Patterson This marriage is off to a shaky start. The groom just asked the band to play "Your cheatin' heart", and the bride just requested "Don't come home a'drinkin' with lovin' on your mind". |
PA28: Difference in constant speed prop vs fixed pitch | Nathan Young | Owning | 25 | October 10th 04 04:41 AM |
Is there a minimum prop speed? | Jim Carter | Owning | 2 | June 29th 04 01:49 AM |
Constant Speed Prop vs Variable Engine Timing | Jay | Home Built | 44 | March 3rd 04 10:08 PM |
Rotax 914 / Constant Speed? | Richard Riley | Home Built | 4 | February 26th 04 03:01 PM |
IVO props... comments.. | Dave S | Home Built | 16 | December 6th 03 11:43 PM |
