Practicing SFLs with a constant speed prop - how?
Old April 13th 04, 04:06 AM
Dave S
One caveat.. this works fine as long as the prop continues to windmill..
if it DOESNT... they you have just turned a training situation into what
may be a bonafide emergency.
Dave
EDR wrote:
In article , Dale
IMO for practice you should leave the prop in the Hi RPM position so
that it provides plenty of drag. Regardless of how you simulate the
engine failure you will be getting some thrust from the engine which
does improve the glide performance. When the real thing happens you
could be caught short if expecting the performance you experienced when
practicing. Putting the prop to the Low RPM position should provide
less drag in an actual engine out situation.
The way I do deadstick landings is to put most of the drag out early and
stay very tight to the field. My thought is I can always get rid of
some drag if needed.
The way I've practiced and done them real life is to leave the prop at
Hi RPM. I also turn base abeam my intended landing point and put the
flaps down full. I fly an extremely tight pattern to prevent coming up
short. IF it appear I might be a little short I can reduce RPM on the
prop and/or reduce the flap setting some (Cessna 182/206) to reduce
drag. It's what I practiced and it's what has worked for me "real life".
The best way to simulate an engine failure without producing thrust is
to pull the mixture all the way out.
When you want to bring the power back, just push the mixture back in
and the engine will restart.
Old April 13th 04, 04:18 PM
Dylan Smith
I believe Highflyer has a story about that in a Taylorcraft...which
lacked an electric starter, and the prop had stopped turning. Slope
soaring saved the day.
Dylan Smith, Castletown, Isle of Man
Flying: http://www.dylansmith.net
Frontier Elite Universe: http://www.alioth.net
"Maintain thine airspeed, lest the ground come up and smite thee"
PA28: Difference in constant speed prop vs fixed pitch Nathan Young Owning 25 October 10th 04 04:41 AM
Is there a minimum prop speed? Jim Carter Owning 2 June 29th 04 01:49 AM
Constant Speed Prop vs Variable Engine Timing Jay Home Built 44 March 3rd 04 10:08 PM
Rotax 914 / Constant Speed? Richard Riley Home Built 4 February 26th 04 03:01 PM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
