Constant speed prop oil leak
Old April 20th 04, 03:39 PM
Newps
"Jim Weir" wrote in message
How do you belly a 182 in?
By landing at 10 AGL. Happens all the time.
Old April 20th 04, 04:50 PM
John Clonts
He's flying a 210...
Cheers,
John Clonts
Temple, Texas
N7NZ C210M
Jim Weir wrote in message . ..
DP
-On Mon, 19 Apr 2004 13:56:24 -0600, "Newps"
-wrote:
-Assuming normal wear and tear an overhaul on a 2 blade McCauley for your
-typical 182 will run $2K.
-This was a new prop back in 1994/5 (don't have my logs right here).
-The last owner belied it in
http://www.rst-engr.com
Old April 21st 04, 05:54 AM
OP
On Mon, 19 Apr 2004 21:58:55 -0700, Jim Weir wrote:
Older 172's and 182's come in RG versions. Never have seen a 152RG though.
Ron Kelley
That's real HARD with the gear down and welded, don'cha know?
OP
-On Mon, 19 Apr 2004 14:57:20 -0700, Jim Weir wrote:
-How do you belly a 182 in?
-Jim
-The same way you belly in a 172.... forget to put the gear down. ;-)
-Ron Kelley
Old April 21st 04, 10:15 PM
John Galban
OP wrote in message . ..
I have, though it was not intentional and the gear only retracted once :-)
PA28: Difference in constant speed prop vs fixed pitch Nathan Young Owning 25 October 10th 04 04:41 AM
Is there a minimum prop speed? Jim Carter Owning 2 June 29th 04 01:49 AM
Why do constant speed power setting charts limit RPM? Ben Jackson Piloting 6 April 16th 04 03:41 AM
Practicing SFLs with a constant speed prop - how? Ed Piloting 22 April 16th 04 02:42 AM
Constant Speed Prop vs Variable Engine Timing Jay Home Built 44 March 3rd 04 10:08 PM
