Fortunately, the chances you cite are not criteria for NAS design.
In engineering a workable NAS I would prefer that the designers employ methodologies that _insure_ separation of air traffic, not merely reduce the _chances_ of a MAC. Anything less is irresponsible negligence. In any system, there's always a small probability that a catastrophe will occur. Aircraft certification rules and separation standards acknowledge this and are established to keep the risk acceptably low. For example, for lateral separation of two aircraft traveling at the same flight level on parallel routes, the Target Level of Safety (TLS) set by ICAO (with FAA participation) is 5 x 10^-9 per flight hour. That is, loss of lateral separation should lead to no more than one accident every 200 million flight hours. The TLS is not zero. Some people don't like to accept this, but it's just not realistic to insist on zero risk. Barry |
On Sat, 24 Apr 2004 11:44:10 -0400, "Barry" wrote in
Message-Id: : Fortunately, the chances you cite are not criteria for NAS design. In engineering a workable NAS I would prefer that the designers employ methodologies that _insure_ separation of air traffic, not merely reduce the _chances_ of a MAC. Anything less is irresponsible negligence. In any system, there's always a small probability that a catastrophe will occur. Aircraft certification rules and separation standards acknowledge this and are established to keep the risk acceptably low. For example, for lateral separation of two aircraft traveling at the same flight level on parallel routes, the Target Level of Safety (TLS) set by ICAO (with FAA participation) is 5 x 10^-9 per flight hour. That is, loss of lateral separation should lead to no more than one accident every 200 million flight hours. The TLS is not zero. Some people don't like to accept this, but it's just not realistic to insist on zero risk. Barry Thank you for the information. How would the TLS be affected if the Big Sky theory were relied upon for aircraft separation as John T. suggested? |
![]() How would the TLS be affected if the Big Sky theory were relied upon for aircraft separation as John T. suggested? I'm not very familiar with this subject, but you can read "Safety Considerations for Operation of Small Unmanned Aerial Vehicles in Civil Airspace" produced by the MIT International Center for Air Transportation: http://icat-server.mit.edu/Library/f....cgi?idDoc=205 They studied both midair collisions and exposure to people on the ground. The relevant conclusions for midairs: Significant Amount of Airspace with Exposure Risk Below the Target Level of Safety - Areas around major airports are above the TLS Opportunities may exist to allow a class of small UAV’s to operate with limited restrictions - Limiting operation in airspace near airports may achieve TLS Mitigation Strategies Are Available to Further Reduce the Risk -Vehicles can be designed with capabilities to limit likelihood of midair collisions Barry |
"Barry" wrote in message
... How would the TLS be affected if the Big Sky theory were relied upon for aircraft separation as John T. suggested? I'm not very familiar with this subject, but you can read "Safety Considerations for Operation of Small Unmanned Aerial Vehicles in Civil Airspace" produced by the MIT International Center for Air Transportation: http://icat-server.mit.edu/Library/f....cgi?idDoc=205 They studied both midair collisions and exposure to people on the ground. The relevant conclusions for midairs: Significant Amount of Airspace with Exposure Risk Below the Target Level of Safety - Areas around major airports are above the TLS Opportunities may exist to allow a class of small UAV's to operate with limited restrictions - Limiting operation in airspace near airports may achieve TLS Mitigation Strategies Are Available to Further Reduce the Risk -Vehicles can be designed with capabilities to limit likelihood of midair collisions This study attempts to 'bound' the danger through a Bayesian analysis of engine failure probability and chances of hitting something at random in the airspace 'per flight hour'. In high traffic areas, the probability is small (10-8). But the total accident rate will depend on how many of these things are flying around. There is nothing about 'accountability' in the "Mitigation Strategies", which is very odd since accountability looms very large in current aviation practice (and FAA regulation). I'm concerned that the model for this sees a UAV "pilot" as a sort of hands-on air traffic controller, rather than as a proper "pilot" with the attendant certification and responsibility requirements. This is a major departure from existing practice, and potentially devastating for GA. |
![]() "Tony Cox" wrote in message ink.net... "Barry" wrote in message ... How would the TLS be affected if the Big Sky theory were relied upon for aircraft separation as John T. suggested? I'm not very familiar with this subject, but you can read "Safety Considerations for Operation of Small Unmanned Aerial Vehicles in Civil Airspace" produced by the MIT International Center for Air Transportation: http://icat-server.mit.edu/Library/f....cgi?idDoc=205 They studied both midair collisions and exposure to people on the ground. The relevant conclusions for midairs: Significant Amount of Airspace with Exposure Risk Below the Target Level of Safety - Areas around major airports are above the TLS Opportunities may exist to allow a class of small UAV's to operate with limited restrictions - Limiting operation in airspace near airports may achieve TLS Mitigation Strategies Are Available to Further Reduce the Risk -Vehicles can be designed with capabilities to limit likelihood of midair collisions This study attempts to 'bound' the danger through a Bayesian analysis of engine failure probability and chances of hitting something at random in the airspace 'per flight hour'. In high traffic areas, the probability is small (10-8). But the total accident rate will depend on how many of these things are flying around. There is nothing about 'accountability' in the "Mitigation Strategies", which is very odd since accountability looms very large in current aviation practice (and FAA regulation). I'm concerned that the model for this sees a UAV "pilot" as a sort of hands-on air traffic controller, rather than as a proper "pilot" with the attendant certification and responsibility requirements. This is a major departure from existing practice, and potentially devastating for GA. I had an opportunity to speak with a Marine who operates UAVs as the remote pilot. He said he and others doing that job must be instrument rated pilots and the UAV must be on an IFR flight plan. Given that, why would the accident rate for UAVs be any different than normal IFR traffic? |
"William W. Plummer" wrote in message
news:rhVic.20812$YP5.1530448@attbi_s02... I had an opportunity to speak with a Marine who operates UAVs as the remote pilot. He said he and others doing that job must be instrument rated pilots and the UAV must be on an IFR flight plan. That may be true in his case (instrument rated pilot), but it isn't required according to Larry's original post. Given that, why would the accident rate for UAVs be any different than normal IFR traffic? 1) Conventional traffic must "See and avoid" when in VMC even if flying IFR. 2) The remote "pilot" doesn't need to keep alert to the extent that the rest of us do because his life isn't on the line. |
Who's At Fault in UAV/Part91 MAC? | Larry Dighera | Instrument Flight Rules | 24 | April 29th 04 03:08 PM |
Thunderbird pilot found at fault in Mountain Home AFB crash | Ditch | Military Aviation | 5 | January 27th 04 01:32 AM |
It's not our fault... | EDR | Piloting | 23 | January 5th 04 04:05 AM |
Sheepskin seat covers save life. | Kevin | Owning | 21 | November 28th 03 10:00 PM |
Senators Fault Air Force on Abuse Scandal | Otis Willie | Military Aviation | 4 | October 2nd 03 05:46 AM |
