#11
My stuff came from the 11/01/2001 Chicago Sectional so revisions are
possible. But I would have to question your statement: "Milwaukee's varies with runway usage. Sometimes it's along runway 7/25, sometimes it's along runway 1/19". How often would a pilot know the active runway prior to calling Approach? I just don't see anything other than a fixed point being used for this purpose. "Steven P. McNicoll" wrote in message hlink.net... "Bill Denton" wrote in message ... The split for the Madison Class C is East and West. The split for the Milwaukee Class C is Southeast and Northwest. Milwaukee's split, like Madison's, is along the extended runway centerline. Madison's is fixed along runway 18/36, but Milwaukee's varies with runway usage. Sometimes it's along runway 7/25, sometimes it's along runway 1/19. |
... [...] But I would have to question your statement: "Milwaukee's varies with runway usage. Sometimes it's along runway 7/25, sometimes it's along runway 1/19". How often would a pilot know the active runway prior to calling Approach? Seattle has a similar situation. Before calling Approach, you listen to the ATIS, because the sector divisions (some of them) depend on which direction the traffic is flowing. So the answer to your question is: listen to the ATIS. It's not like they are keeping the active runway secret until you actually talk to them. "Seattle Approach, Cessna 12345, 20 miles west, 2000', pssst what runway are you guys using?" Pete |
Thanks for the info...
"Peter Duniho" wrote in message ... "Bill Denton" wrote in message ... [...] But I would have to question your statement: "Milwaukee's varies with runway usage. Sometimes it's along runway 7/25, sometimes it's along runway 1/19". How often would a pilot know the active runway prior to calling Approach? Seattle has a similar situation. Before calling Approach, you listen to the ATIS, because the sector divisions (some of them) depend on which direction the traffic is flowing. So the answer to your question is: listen to the ATIS. It's not like they are keeping the active runway secret until you actually talk to them. "Seattle Approach, Cessna 12345, 20 miles west, 2000', pssst what runway are you guys using?" Pete |
![]() "Peter Duniho" wrote in message ... Someone else answered that. You don't need a VOR receiver to be able to know where a VOR radial is, when flying VFR. No navigation equipment is required for VFR entry of Class B or C airspace. How does one know where a VOR radial is without using any navigation equipment? |
![]() "Bill Denton" wrote in message ... But I would have to question your statement: "Milwaukee's varies with runway usage. Sometimes it's along runway 7/25, sometimes it's along runway 1/19". Well, that's the way it is. It's specified that way in the Letter of Agreement between Milwaukee approach and Chicago Center. I'm familiar with the letter because I was a controller at Chicago Center. How often would a pilot know the active runway prior to calling Approach? A pilot would know the active runway upon listening to the ATIS. If he does that before he calls approach then he knows the active runway prior to calling approach. I just don't see anything other than a fixed point being used for this purpose. Believe what you wish. |
news ![]() No navigation equipment is required for VFR entry of Class B or C airspace. So? What's that got to do with this thead? How does one know where a VOR radial is without using any navigation equipment? Look at your chart. When you can see out the window, this is a much more reliable way of identifying a VOR radial than using the actual radio (which is permitted to have as much as 6 degrees of error anyway). Pete |
Thanks for the info!
"Steven P. McNicoll" wrote in message . net... "Bill Denton" wrote in message ... But I would have to question your statement: "Milwaukee's varies with runway usage. Sometimes it's along runway 7/25, sometimes it's along runway 1/19". Well, that's the way it is. It's specified that way in the Letter of Agreement between Milwaukee approach and Chicago Center. I'm familiar with the letter because I was a controller at Chicago Center. How often would a pilot know the active runway prior to calling Approach? A pilot would know the active runway upon listening to the ATIS. If he does that before he calls approach then he knows the active runway prior to calling approach. I just don't see anything other than a fixed point being used for this purpose. Believe what you wish. |
![]() "Peter Duniho" wrote in message ... So? What's that got to do with this thead? It was a response to the statement, "You don't need a VOR receiver to be able to know where a VOR radial is, when flying VFR." You don't see the connection? Look at your chart. When you can see out the window, this is a much more reliable way of identifying a VOR radial than using the actual radio (which is permitted to have as much as 6 degrees of error anyway). Please explain how it's done. |
I don't have an operational problem with using the chart and I know
that approach control won't go crazy if I somehow manage to use the wrong frequency. My issue is being told by a designated examiner something that a: doesn't make sense and b: she can't back up with a source It's not the radials that's the problem, it's the selected starting point from where the bearings in the legend should extend. Claiming that the bearings should extend from anything other than the primary airport for the airspace seems crazy to me. Apart from the fact that some airports don't have VORs, even if it does, your not flying to a VOR, you're flying to the airport and the airport and VOR don't necessarily have to be co-located so to me, the reference point naturally should be the airport and not any nav-aid that happens to be in the area. But like I said, I'd like to find a proper source where I can read about these charts. On 2004-04-24 12:33:25 -0400, "Steven P. McNicoll" said: "Peter Duniho" wrote in message ... Someone else answered that. You don't need a VOR receiver to be able to know where a VOR radial is, when flying VFR. No navigation equipment is required for VFR entry of Class B or C airspace. How does one know where a VOR radial is without using any navigation equipment? |
![]() "Magnus" wrote in message ... I don't have an operational problem with using the chart and I know that approach control won't go crazy if I somehow manage to use the wrong frequency. My issue is being told by a designated examiner something that a: doesn't make sense and b: she can't back up with a source Indicators that she's quite probably mistaken. |
Florida Mil and NASA Comms Log - Tues, 18 May 2004 | AllanStern | Military Aviation | 4 | July 10th 04 02:00 AM |
Florida Military Comms Log - Thurs 15 Apr 2004 | AllanStern | Military Aviation | 1 | April 17th 04 08:38 PM |
Lost comms after radar vector | Mike Ciholas | Instrument Flight Rules | 119 | January 31st 04 11:39 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
