![]() "Ron Natalie" wrote in message m... One thing that VFR's should note, that while participation is voluntary in the TRSA, many TRSA towers get a bit testy if you don't go in through the TRSA-approach control. Sure, because now they've gotta find you and sequence you. If all VFR arrivals use TRSA services, which require separation between all aircraft, sequencing is automatic. |
In article . net,
"Steven P. McNicoll" wrote: "Ron Natalie" wrote in message m... One thing that VFR's should note, that while participation is voluntary in the TRSA, many TRSA towers get a bit testy if you don't go in through the TRSA-approach control. Sure, because now they've gotta find you and sequence you. If all VFR arrivals use TRSA services, which require separation between all aircraft, sequencing is automatic. Idle question: how common are TRSAs? I can find only one in all of California, but that doesn't say much about other parts of the US. Hamish |
I found only one on the Chicago Sectional, at Waterloo (ALO).
"Hamish Reid" wrote in message ... In article . net, "Steven P. McNicoll" wrote: "Ron Natalie" wrote in message m... One thing that VFR's should note, that while participation is voluntary in the TRSA, many TRSA towers get a bit testy if you don't go in through the TRSA-approach control. Sure, because now they've gotta find you and sequence you. If all VFR arrivals use TRSA services, which require separation between all aircraft, sequencing is automatic. Idle question: how common are TRSAs? I can find only one in all of California, but that doesn't say much about other parts of the US. Hamish |
![]() "Bill Denton" wrote in message ... I found only one on the Chicago Sectional, at Waterloo (ALO). ALO does not have a TRSA. http://makeashorterlink.com/?O15B32828 |
![]() "Hamish Reid" wrote in message ... Idle question: how common are TRSAs? I can find only one in all of California, but that doesn't say much about other parts of the US. I know of TRSAs at Rockford, Illinois, and Muskegon and Kalamazoo, Michigan. |
Please review the subject of this thread, which is the use of an "R" in a
circle on Sectional Charts to denote the presence of Airport Surveillance Radar at specific airports. It appears Mr. Reid introduced TRSA's into the mix, a point I failed to note. And it appears that a TRSA is not the same thing as Airport Surveillance Radar. So, my statement, in response to the original subject, that the only Airport Surveillance Radar on the Chicago Sectional is at Waterloo (ALO) is correct, assuming that I found all that were on the chart. And your statement, in response to the changed subject: "I know of TRSAs at Rockford, Illinois, and Muskegon and Kalamazoo, Michigan", is also correct. "Steven P. McNicoll" wrote in message ink.net... "Hamish Reid" wrote in message ... Idle question: how common are TRSAs? I can find only one in all of California, but that doesn't say much about other parts of the US. I know of TRSAs at Rockford, Illinois, and Muskegon and Kalamazoo, Michigan. |
"Bill Denton" wrote: Please review the subject of this thread, which is the use of an "R" in a circle on Sectional Charts to denote the presence of Airport Surveillance Radar at specific airports. Thread drift, it's called :-). It appears Mr. Reid introduced TRSA's into the mix, a point I failed to note. Erm, what?! It appears Ron Natalie, in om, introduced TRSAs into the mix, a point you failed to note: "Ron Natalie" wrote in message m... One thing that VFR's should note, that while participation is voluntary in the TRSA, many TRSA towers get a bit testy if you don't go in through the TRSA-approach control. That was included in the article of mine that you responded to. And it may have been introduced earlier by someone else -- I didn't follow the references all the way. I just happened to notice the reference to TRSAs, and started wondering... And it appears that a TRSA is not the same thing as Airport Surveillance Radar. Well, no -- TRSAs are a lot rarer than ASRs. Which is why I asked the question about TRSAs (having never actually encountered one myself). Such is Usenet, I guess. Hamish |
My apologies if I unduly credited you. Actually, TRSA's were first mentioned
in the second message on this thread. I simply felt your message was the first to directly address TRSA's, as opposed to simply referencing them. In the body of your message, you stated: "TRSAs are a lot rarer than ASRs". However, as has been noted, The Chicago Sectional shows one ASR and three TRSA's, which would contradict your observation. But, given that aviation facilities are unevenly distributed around the nation, I would not find that surprising! "Hamish Reid" wrote in message ... In article , "Bill Denton" wrote: Please review the subject of this thread, which is the use of an "R" in a circle on Sectional Charts to denote the presence of Airport Surveillance Radar at specific airports. Thread drift, it's called :-). It appears Mr. Reid introduced TRSA's into the mix, a point I failed to note. Erm, what?! It appears Ron Natalie, in om, introduced TRSAs into the mix, a point you failed to note: "Ron Natalie" wrote in message m... One thing that VFR's should note, that while participation is voluntary in the TRSA, many TRSA towers get a bit testy if you don't go in through the TRSA-approach control. That was included in the article of mine that you responded to. And it may have been introduced earlier by someone else -- I didn't follow the references all the way. I just happened to notice the reference to TRSAs, and started wondering... And it appears that a TRSA is not the same thing as Airport Surveillance Radar. Well, no -- TRSAs are a lot rarer than ASRs. Which is why I asked the question about TRSAs (having never actually encountered one myself). Such is Usenet, I guess. Hamish |
![]() "Bill Denton" wrote in message ... In the body of your message, you stated: "TRSAs are a lot rarer than ASRs". However, as has been noted, The Chicago Sectional shows one ASR and three TRSA's, which would contradict your observation. Actually it wouldn't, as the presence of ASR is indicated by the depiction of Class B or Class C airspace, by a TRSA, or by the little blue R. |
N94 Airport may expand into mobile home community, locals supportive | William Summers | Piloting | 0 | March 18th 04 03:03 AM |
Rules on what can be in a hangar | Brett Justus | Owning | 13 | February 27th 04 05:35 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
NACO charts - why have a reference circle? | Bob Gardner | Instrument Flight Rules | 5 | September 6th 03 01:15 PM |
