Rental policy
Old May 6th 04, 09:23 PM
Roger Long
Hmm, reading Peter's post above dissecting the time order of the wording, I
guess I would want a clarification before renting. It looks to me as though
it was written so that a renter rolling the dice by flying away from the
homebase with a known problem would be responsible. Peter is right though,
if a pilot returned from lunch at a distant airport and found fuel running
out of the wings, the wording could be used to hold him to the rest of it.
If the "being flown" in the first line was replace by "departing the home
base" or "accepting the aircraft for flight" I would consider it reasonable.
Roger Long
Old May 6th 04, 09:45 PM
Bill Denton
You made the statement: "if a pilot returned from lunch at a distant airport
and found fuel running out of the wings, the wording could be used to hold
him to the rest of it" is not correct.
The wording in that section would only apply if the pilot knew there was a
fuel leak (or something similar or related) prior to flying the aircraft.
If the pilot was not aware of a fuel system or related problem prior to
taking off, he would not be liable under this section of the rental
agreement. However, I would imagine there would be other sections covering
this type of situation.
"Roger Long" om wrote in
message ...
I
though
though,
reasonable.
Roger Long
Old May 6th 04, 09:57 PM
Todd Pattist
"If the PIC determines that the plane needs repair before
being flown, .. "
I come back from lunch at a distant airport and the aircraft
is leaking fuel. I've now determined it needs repair and I
haven't yet flown (home.)
" and the PIC has flown the plane away from its home
location,"
I've previously flown the plane to the "distant airport."
I agree with Peter - the wording seems to cover someone who
finds out at a remote location that he needs repair before
coming home. At best, it's ambiguous.
Todd Pattist
(Remove DONTSPAMME from address to email reply.)
___
Make a commitment to learn something from every flight.
Share what you learn.
Bush's Attempt to Usurp the Constitution WalterM140 Military Aviation 20 July 2nd 04 04:09 PM
Showstoppers (long, but interesting questions raised) Anonymous Spamless Military Aviation 0 April 21st 04 05:09 AM
No US soldier should have 2 die for Israel 4 oil Ewe n0 who Military Aviation 1 April 9th 04 11:25 PM
No US soldier should have 2 die for Israel 4 oil Ewe n0 who Naval Aviation 0 April 7th 04 07:31 PM
CBS Newsflash: Rental trucks pose imminent and grave danger to national security Ron Lee Piloting 4 January 15th 04 03:07 PM
