![]() Paul, it will depend on your specific model of meter. If it's the kind that reads SWR directly & has a "cal" knob for the meter no mods are needed, just set your meter the same as you would for a CB, the SWR measurment will be right. If it's the "forward & reverse power" variety there should be trim pot adjustments inside the case to adjust the meter to read watts correctly but you'll need to lay your hands on an accurate meter (Bird 43 w/correct slugs recommended) for that frequency range to compare yours against. Just hook them in series & adjust yours to read the same as the "good" one. Just for comparison, I've got a 30 year old RS CB power-modulation-vswr combo meter that reads pretty much correctly at 148 mhz, so if yours is off it probably won't be by much. Have fun, don't let the smoke out ![]() Howard. On 31 May 2004 22:31:31 -0700, (Paul Lee) wrote: I just posted a question on the RS SWR meter and the thread dissapeared. Here is my question again. Is there some way of modifying the Radio Shack SWR meter (27MHZ) to make it work in the aircraft radio range (120MHZ)? I am not asking if I should use it or not but what circuit modification can be done so it centers in the aircraft VHF frequencies. SWR circuitry is usually simple and the RS SWR meter already's got the meter and knobs. Anybody's done that already? |
SWR meter | Paul Lee | Home Built | 3 | May 31st 04 02:47 PM |
Marine Radio using Aviation Antennae | Jim Weir | Home Built | 13 | August 12th 03 10:05 PM |
Radio squeal | Gerrie | Home Built | 4 | August 5th 03 09:28 PM |
Oshkosh Bound With Ham Radio | Jim Weir | Home Built | 13 | July 15th 03 02:35 PM |
Ham Radio In The Airplane | Doug Carter | Home Built | 24 | July 8th 03 03:30 AM |
