High or low wing?
Old May 9th 04, 04:08 AM
Teacherjh
I also like the fact that, at least in the 172, there is generally no
need to switch tanks (there is a "Both" setting)
But when your'e out of gas, you're out of gas.
JOse
(for Email, make the obvious changes in my address)
Old May 10th 04, 02:03 AM
G.R. Patterson III
But when the fuel pump breaks, my engine keeps running.
George Patterson
If you don't tell lies, you never have to remember what you said.
Old May 10th 04, 01:25 PM
David Megginson
Low-wing planes normally have an electric fuel pump to back up the pump
attached to the engine's accessory drive. Still, in this case, gravity is a
simpler and more elegant solution than an extra gadget.
All the best,
David
High wing to low wing converts...or, visa versa? Jack Allison Owning 99 January 27th 05 11:10 AM
High wing vs low wing temp Owning 11 June 10th 04 02:36 AM
High Wing or Low Wing Bob Babcock Home Built 17 January 23rd 04 01:34 AM
End of High wing low wing search for me dan Home Built 7 January 11th 04 10:57 AM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 03:40 PM
