"Aluminum Overcast" damaged by gear collapse
Old May 13th 04, 03:28 PM
G.R. Patterson III
Rick Durden wrote:
CAF is already saying the copilot pulled the gear up when he went for
the flaps, despite being told to keep his hands off the flap switch
until off the runway.
As of today, EAA still denies this. They state that videos indicate that the gear was
not completely down when the plane landed.
George Patterson
I childproofed my house, but they *still* get in.
Old May 13th 04, 05:30 PM
Dale
gear was
I guess that's possible. Would have to be a real good quality video
since you'd have to be able to see if the scissor is overcenter.
And, if they weren't down and locked the crew either wasn't doing their
job or their procedures were bad. You can look at the gear from the
cockpit and tell if it is locked down. That was our procedure on gear
extension...a visual check that the gear was down and locked.
And again, might odd that both gear suffered the same failure at the
same time since they are separate systems....only common thing being the
switch in the cockpit. And just because one gear fails there is no
reason for the "good" gear to collapse....lots of cases of B-17s landing
with only one gear down.
Dale L. Falk
Old May 13th 04, 11:41 PM
G.R. Patterson III
Only thing I can think of is that both motors quit prematurely.
George Patterson
Old May 14th 04, 09:24 PM
gatt
"G.R. Patterson III" wrote in message .
Noticed that it looks like the ball turret remained intact. That's very
interesting.
My father's crew had a close call coming back from Gdynia, Poland in 1943
straight out of every B-17 movie made afterward; mains blown out by flak,
ball turret jammed, plane coming home low on fuel and they had crossed the
Wash before they managed to get the guy out; as soon as they landed, wheels
up, the PAO had them formed up in front of an undamaged airplane for a
photo.
Interesting to know that Fred Holt might have survived anyway.
-c
Old May 14th 04, 11:14 PM
G.R. Patterson III
Key word is "might". With "Aluminum Overcast", the gear collapse happened when the
plane was traveling at most 30 mph. I'd say there would probably be a big difference
if that turret hits the runway at about 90.
George Patterson
EAA's B-17 "Aluminum Overcast" Gear collapse at Van Nuys airport BlakeleyTB Home Built 4 May 8th 04 06:15 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
