"Keith Willshaw" wrote: The problem is that merely reaching the altitude is only a part of the problem. The real issue is achieving orbital velocity No, it's not. http://www.xprize.org/teams/guidelines.html "3. The flight vehicle must be flown twice within a 14-day period. Each flight must carry at least one person, to minimum altitude of 100 km (62 miles). The flight vehicle must be built with the capacity (weight and volume) to carry a minimum of 3 adults of height 188 cm (6 feet 2 inches) and weight 90 kg (198 pounds) each. Three people of this size or larger must be able to enter, occupy, and be fastened into the flight vehicle on Earth's surface prior to take-off, and equivalent ballast must be carried in-flight if the number of persons on-board during flight is less than 3 persons." -- cirby at cfl.rr.com Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly. |
![]() "Chad Irby" wrote in message .com... In article , "Keith Willshaw" wrote: The problem is that merely reaching the altitude is only a part of the problem. The real issue is achieving orbital velocity No, it's not. http://www.xprize.org/teams/guidelines.html I'm aware of the rules of the X prize. Lots of posters in this thread have made comparisons with NASA and alluded to civilian space flight. You need to achieve orbital velocity to do that. Keith |
Rutan hits 200k feet! Almost there! | Thomas J. Paladino Jr. | Military Aviation | 150 | May 22nd 04 07:20 PM |
Spaceship 1 hits 212,000 feet!!!!!! | BlakeleyTB | Home Built | 10 | May 20th 04 10:12 PM |
Hiroshima/Nagasaki vs conventional B-17 bombing | zxcv | Military Aviation | 55 | April 4th 04 07:05 AM |
Looking for Cessna Caravan pilots | [email protected] | Owning | 9 | April 1st 04 02:54 AM |
Use of 150 octane fuel in the Merlin (Xylidine additive etc etc) | Peter Stickney | Military Aviation | 45 | February 11th 04 04:46 AM |
