High or low wing?
Old May 15th 04, 12:02 AM
G. Burkhart
Thanks, George, for the detailed information on this. One question I have;
what is the fuel burn difference between the models/years?
-Greg B.
"G.R. Patterson III" wrote in message
David Megginson wrote:
G.R. Patterson III wrote:
I doubt it. The 172 performs better on less power than a PA-28 from
the same year.
Do you have a source for that?
According to Clarke's "The Illustrated Buyer's Guide to Used Aircraft",
the PA-28 was
introduced in 1961. At that time, the 172 had a 145hp engine, cruised at
130 mph, and
the difference between max gross and empty weight was 1040 lbs. The PA-28
had 150hp,
cruised at 130 mph, and the difference in the two weights was 945 lbs.
With the
optional 160hp engine, cruise went up to 132 mph and capacity to 990 lbs
for the
PA-28.
In 1963, the PA-28s with 180hp engines became available, which made the
plane 11 mph
faster than the 172 (which still had 145hp). Carrying capacity also went
up to 1175
lbs, which exceeded the Cessna's for the first time. Note that 150hp and
160hp
versions were still being produced, so whether a PA-28 built during the
mid-60s can
out-perform a 172 of the same period, depends on the engine in the Piper.
In 1968, Cessna went to 150hp, which boosted cruise speed to 138 mph
(still 3 mph
slower than the 180hp Piper but faster than the 160hp model). Capacity
went down to
986 lbs.
In 1974, Piper introduced the PA-28-151. With 150hp, the cruise was 126
mph (12 mph
slower than the Cessna), but the plane could carry 1024 lbs.
In 1977, both Cessna and Piper went to 160 hp. For Cessna, this was the
infamous "H"
series engine. Cruise for the Cessna stayed 138 mph and capacity stayed
986 lbs
(though max gross went up) Cruise for the Piper was 140 mph and capacity
dropped to
972 lbs.
Piper continued to make 180hp planes, and the PA-28-161, introduced in
1976, cruises
at 148 mph and carries 1137 lbs, both being significantly higher values
than those
for the 172 of the period.
George Patterson
I childproofed my house, but they *still* get in.
  #142
Old May 15th 04, 12:11 AM
G.R. Patterson III
Clarke doesn't have fuel burn figures, but consumption is usually about 0.055 gallons
per horsepower.
George Patterson
  #143
Old May 15th 04, 07:26 AM
Roger Halstead
On Fri, 14 May 2004 23:11:53 GMT, "G.R. Patterson III"
per horsepower.
The old PA28-180, Hershey bar wing Cherokee 180 burns between 8 and 10
GPH, depending on how hard you push it.
It may have been physiological, but it seemed like the difference
between the 180s and the er... lesser models was like night and day.
You can tell I prefer the 180:-))
It was a great short field plane and to me all of the Cherokees ride
the bumps much better than the Cessnas of the same size.
George Patterson
They're worse 'n ants.
www.rogerhalstead.com
  #144
Old May 15th 04, 10:40 AM
Martin Hotze
On Sat, 08 May 2004 22:30:39 GMT, Jay Honeck wrote:
We've been fighting for years on this subject with Jim Fisher and Jay
Honeck, trying to convince them that low-wingers are more masculine and
overall a better choice for real pilots, but they won't listen
Don't let him fool you, Doc Williams -- HECTOP is a known high-wing pilot
and Communist sympathizer. And we all know what them Com-simps are all
that must be the reason whz he left Russia back then ...
about, now DON'T we....?
martin
If John and Peter get together and take money from Paul at gunpoint,
we call it armed robbery. If two thousand voters get together
and decide to take money from another thousand, we call it taxation.
C J Campbell in rec.aviation.piloting
  #145
Old May 15th 04, 11:37 AM
Jay Honeck
The only immutable thing I've learned from airplane ownership is this:
There is no substitute for horsepower.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
  #146
Old May 15th 04, 11:53 AM
Bob Noel
In article Fpmpc.53004$xw3.3200075@attbi_s04, "Jay Honeck"
even more important:
aerodynamics (compare the twin Comanche to the Apache).
and, of course, money
Bob Noel
  #147
Old May 15th 04, 01:27 PM
EDR
In article Fpmpc.53004$xw3.3200075@attbi_s04, Jay Honeck
.... and horsepower = $$$
And we all know there is no substitute for more $$$!
High wing to low wing converts...or, visa versa? Jack Allison Owning 99 January 27th 05 11:10 AM
High wing vs low wing temp Owning 11 June 10th 04 02:36 AM
High Wing or Low Wing Bob Babcock Home Built 17 January 23rd 04 01:34 AM
End of High wing low wing search for me dan Home Built 7 January 11th 04 10:57 AM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 03:40 PM
