Airway emergency - what would you have done.
Old May 18th 04, 05:03 AM
Peter Duniho
"JJS" jschneider@REMOVE SOCKSpldi.net wrote in message
[...] I tried hitting her on the back hard enough that I
knew she'd kill me if she lived through the ordeal.
Ack. Thank goodness you didn't wind up lodging the obstruction in even
further. Remember: gravity is at work, even inside your body. Knock
something loose that's inside your airway, and the most likely place for it
to go is down.
The last thing a person having trouble breathing needs is a whack on the
back. At least, not until you turn them upside down. I'm surprised with
all your emergency medical training, no one's mentioned this.
The traditional Heimlich is done from behind, of course, but it seems to me
that with a strong enough arm, especially with a partial obstruction, you
might have had some luck from the side. Just get your fist in good under
her diaphragm (not, not THAT diaphragm...this is serious you guys ), and
push hard and quick, in the same motion you'd use from behind.
It would at least be worth a try.
Barring success getting the thing out quickly, I can't imagine flying all
the way to an airport, even one nearby. You should have appropriate landing
sites below you nearly all the time. A passenger choking seems to me to be
just as serious as an airplane on fire, and would warrant an emergency
descent to an off-airport landing so that proper first-aid (e.g. a real
from-behind Heimlich) can be given.
Pete
Old May 19th 04, 12:16 AM
JJS
even
Knock
for it
to go is down.
That was my concern too, Pete. She wasn't exactly sitting upright,
though. She was doubled over, gagging more than coughing.
with
I'd do it again... you probably had to be there to understand. It is
hard to describe her condition and varying positions with words.
Sometimes she was bent over like she was about to vomit into a toilet
positioned between the yokes. She would have gladly done so if
possible. Rember this took place over several minutes.
seems to me
obstruction, you
under
), and
Thank goodness it never came to the point that I needed to try it.
Your suggested method was on my list. I'd probably have kept trying
various things until successful or we were on the ground.
flying all
landing
Landing sites are few and far between in that neck of the woods. If
you have a chart of the area and are unfamiliar, take a look. I think
Aeroplanner might show the sectional if you want to try that.
emergency
real
I agree and that was my plan if things progressively got worse. The
situation wasn't static. A million things ran through my mind. You
are correct about the traditional Hiemlich being done from behind but
there is also a modified version for a person who is passed out and
lying on the floor. You roll them on their back, straddle them while
kneeling and force air out of their lungs from the front side of the
victim.
Pete
Emergency Parachute questions Jay Moreland Aerobatics 14 December 3rd 04 05:46 PM
Military jet makes emergency landing at MidAmerica Otis Willie Military Aviation 0 September 1st 03 02:28 AM
Emergency landing at Meigs Sunday Thomas J. Paladino Jr. Piloting 22 August 3rd 03 03:14 PM
First Emergency (Long Post) [email protected] Owning 14 July 23rd 03 02:46 AM
