"Newps" wrote in message ...
"Dan Thomas" wrote in message om... The student has to maintain control of an unruly airplane and has to be able to read a map, use a wet compass and and a watch. Huh? Once in the air a plane is a plane. Maybe yours isn't rigged right. Oh, man. Have you never flown a Champ or Cub or some other older design that had lots of adverse yaw, and that might flick over into a spin if you skidded it around the base-to-final turn? One that required some serious attention in most maneuvers if you were going to gain any proficiency in it at all? Even if it's rigged perfectly? These older designs make the pilot aware of his need for precision, and once he learns it his flying of all other aircraft improves enormously. In 12 years here I've seen these taildraggers cure a lot of sloppiness. We've used them to demonstrate the skidding-turn spin, thereby showing the student what eventually awaits him if he gets stupid at low altitude. Some guys get their PPL in a 172 or Warrior and then go buy an old 140 or Champ or Tri-Pacer and get into trouble almost immediately. We also use the Citabria for emergency maneuvers training (basic aerobatics) to show the control inputs required to get an airplane upright again if control is lost in extreme turbulence or wake turbulence. Try THAT in a 172. A plane is not a plane. That idea has killed way to many uninitated folks. Dan |
![]() Oh, man. Have you never flown a Champ or Cub or some other older design that had lots of adverse yaw, and that might flick over into a spin if you skidded it around the base-to-final turn? is this behavior =caused= by the position of the middle wheel, or is it just coincidence and history that they are taildraggers? Jose -- (for Email, make the obvious changes in my address) |
In article , Dan Thomas wrote:
Taildraggers tend to be older designs, and older designs often didn't have the benign behaviour of newer designs, which tend to be nosewheel airplanes. So taildraggers, while the gear has no effect in the air, are usually harder to fly and require more effort and understanding. Actually, many of these older aircraft aren't really much harder at all. Some are, many aren't. Our C140 for example was easy and pleasant to fly, with light control forces and a good strong rudder. It required a lot more finesse on landing than a nosewheel plane of course, and I think that improved my finesse when flying any aircraft. But it just wasn't difficult to fly, just a bit different. I think that was reflected by our insurance rates - we had at one time a zero-hours student on the insurance, and the extra cost compared to a C150 of the same hull value was IIRC only about $50/year. I never had a nasty moment (although I did botch some landings) in the C140, and that included landing in a 20 knot direct crosswind (which I have on video). My aircraft insurance for a $20,000 hull value and $1M liability insurance was significantly cheaper than the insurance on my Ford F150, worth $8000 at the time (and I have no accidents/tickets). The Auster on the other hand...actually, in the air, it flies a lot like a C172 with a stick instead of a yoke (and climbs a lot better, it weighs about 500lbs less and has an O-320) - very little adverse yaw etc. is an absolute bear to land nicely. Partly because you can't see anything forwards in the three point attitude, partly because it has a free castoring tailwheel, and partly because the cable operated heel brakes are virtually impossible to use at the same time as making rudder inputs (heel brakes suck, I'm sorry). Mitigating this though is the approach speed of 50 mph so stuff happens slowly. Should new instructors have to fly something like this? I wouldn't insist on it, but it's a nice-to-have in the increasing the depth of experience department. I think taildragger training is a nice to have but not essential. What is essential is teaching proper technique, and many certificate mill instructors who have little experience outside of flying the traffic pattern are a bit lacking in that area, and it shows in the old wives' tales they tend to repeat. Personally, if there was one additional requirement that I think new CFIs should meet before teaching is a long solo cross country of a good 1000NM. That way they are likely to have had to have made real world weather decisions, have probably had to fly in mountainous terrain and so forth. And my requirement would be to do it by mag compass, chart and clock so they internalize the fundamentals of navigation too. -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
"Dylan Smith" wrote in message:
"And my requirement would be to do it by mag compass, chart and clock so they internalize the fundamentals of navigation too." I think every pilot should have one cross-country with just a compass, chart and clock. I did mine when my husband checked me out in his 8A. It was different. I'd been flying a C-172 with a DG, VOR and GPS. Now, I have an 8E with a handheld GPS, but I still keep my eyeball on my compass heading. You never know when that sucker will die! I've also had hood time in his non-electrical 8A. I flew a two hour cross country using the needle/ball, airspeed, VSI and compass. His airplane is rather slow (about 90 mph). It was a way to pass the time over country I'd seen before. Deb -- 1946 Luscombe 8A (His) 1948 Luscombe 8E (Hers) 1954 Cessna 195B, restoring (Ours) Jasper, Ga. (JZP) ... In article , Dan Thomas wrote: Taildraggers tend to be older designs, and older designs often didn't have the benign behaviour of newer designs, which tend to be nosewheel airplanes. So taildraggers, while the gear has no effect in the air, are usually harder to fly and require more effort and understanding. Actually, many of these older aircraft aren't really much harder at all. Some are, many aren't. Our C140 for example was easy and pleasant to fly, with light control forces and a good strong rudder. It required a lot more finesse on landing than a nosewheel plane of course, and I think that improved my finesse when flying any aircraft. But it just wasn't difficult to fly, just a bit different. I think that was reflected by our insurance rates - we had at one time a zero-hours student on the insurance, and the extra cost compared to a C150 of the same hull value was IIRC only about $50/year. I never had a nasty moment (although I did botch some landings) in the C140, and that included landing in a 20 knot direct crosswind (which I have on video). My aircraft insurance for a $20,000 hull value and $1M liability insurance was significantly cheaper than the insurance on my Ford F150, worth $8000 at the time (and I have no accidents/tickets). The Auster on the other hand...actually, in the air, it flies a lot like a C172 with a stick instead of a yoke (and climbs a lot better, it weighs about 500lbs less and has an O-320) - very little adverse yaw etc. is an absolute bear to land nicely. Partly because you can't see anything forwards in the three point attitude, partly because it has a free castoring tailwheel, and partly because the cable operated heel brakes are virtually impossible to use at the same time as making rudder inputs (heel brakes suck, I'm sorry). Mitigating this though is the approach speed of 50 mph so stuff happens slowly. Should new instructors have to fly something like this? I wouldn't insist on it, but it's a nice-to-have in the increasing the depth of experience department. I think taildragger training is a nice to have but not essential. What is essential is teaching proper technique, and many certificate mill instructors who have little experience outside of flying the traffic pattern are a bit lacking in that area, and it shows in the old wives' tales they tend to repeat. Personally, if there was one additional requirement that I think new CFIs should meet before teaching is a long solo cross country of a good 1000NM. That way they are likely to have had to have made real world weather decisions, have probably had to fly in mountainous terrain and so forth. And my requirement would be to do it by mag compass, chart and clock so they internalize the fundamentals of navigation too. -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
![]() "Dylan Smith" wrote in message ... Personally, if there was one additional requirement that I think new CFIs should meet before teaching is a long solo cross country of a good 1000NM. That way they are likely to have had to have made real world weather decisions, have probably had to fly in mountainous terrain and so forth. And my requirement would be to do it by mag compass, chart and clock so they internalize the fundamentals of navigation too. How do you fly 1000 miles on the Isle of Mann? :-) Anyway, maybe you could take away the chart. Make them really internalize those 'fundamentals.' In fact, let's lose the clock, too. And the compass. Pure fluff. Get rid of it. Then, to make sure he really learns something, let's put a blindfold on him and stop up his ears. And make him fly while being pecked by chickens. With his feet and hands tied together. That'll make a man of him. :-) |
In article , C J Campbell wrote:
Personally, if there was one additional requirement that I think new CFIs should meet before teaching is a long solo cross country of a good 1000NM. That way they are likely to have had to have made real world weather decisions, have probably had to fly in mountainous terrain and so forth. And my requirement would be to do it by mag compass, chart and clock so they internalize the fundamentals of navigation too. How do you fly 1000 miles on the Isle of Mann? :-) Generally by doing that super scary over water thingy! -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
WINGS: When do the clocks start ticking? | Andrew Gideon | Piloting | 6 | February 3rd 04 03:01 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 12:14 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
