In article , Tom Sixkiller
wrote: Let's look at another aspect... The taildragger (regardless of make/model) requires that the pilot raise the nose to land (only slightly for wheel landings). Yes, and so does a tricycle gear. Ever heard of ground loops and nose-overs? I suppose those never happened when everyone learned in tail-draggers. If you ground loop or nose over a tric, you've really screwed up. You can ground loop or nose over either one, the taildragger does a better job of teaching you how not to get in that situation (it the stick/yoke isn't in you gut, you are heading for a problem). It's about proper piloting technique, it has nothing to do with ego. So what equipment is used has noting to do with it, it's how it's taught? So what's all the blather about requiring tail-dragger instruction? Again, the taildragger is a better teacher. If you don't do it right every time, it will bite you. (Although, the theory that it makes women's boobs bigger has marketing potential. ;-)) I think the "ego" problem here is someone inserted their foot in their mouth and is now trying to justify himself. Why was the wheel moved from the back to the front? It is more stable and forgiving, and because of those qualities it allows for more mistakes. |
![]() EDR wrote: If you ground loop or nose over a tric, you've really screwed up. You can ground loop or nose over either one, the taildragger does a better job of teaching you how not to get in that situation (it the stick/yoke isn't in you gut, you are heading for a problem). If the yoke *is* in your gut in my aircraft, you're about to have a big problem (unless you're already on the ground). When the wings stall (as they're about to), the mains will drop faster than the tail. The results can be anywhere from a very hard landing to a seesaw as the mains bounce, bringing the tail down, which bounces, bringing the mains down, which bounce ..... "and awaaayyy we go!" You need to learn the proper attitude for whatever aircraft you fly. Learning to land a Cessna 170 will not improve your landings in a 182. Learning to land a 182 will. George Patterson I childproofed my house, but they *still* get in. |
There's one note of hilarity in here that I'm surprised no one has picked up
on... I think it's probably a safe bet that most of the ardent advocates of tailwheel training drive cars and trucks with automatic transmissions. Even though a manual transmission teaches you more about power management, traction control, and stuff like that than an automatic would. (Of course, you could also learn all of that stuff from "Dukes Of Hazard" reruns.) But from what I've read on this thread, I think tailwheel training probably falls into the same category as does a lot of the other training I see discussed he it's not going to hurt you, but it may not be totally necessary. |
![]() I think it's probably a safe bet that most of the ardent advocates of tailwheel training drive cars and trucks with automatic transmissions. Interestingly, in NY (at least when I got my licence, %& years ago) if you took the test in an automatic, you were legal in a manual. However, if you took the test in a manual, you were restricted to a manual transmission. Go figure. Jose -- (for Email, make the obvious changes in my address) |
![]() However, if you took the test in a manual, you were restricted to a manual transmission. Are you sure about this? Yes, I'm sure. Because it seemed so backward it made an impression. (I took the test in an automatic). Jose -- (for Email, make the obvious changes in my address) |
On Wed, 19 May 2004 13:21:03 -0500, "Bill Denton"
wrote: I think it's probably a safe bet that most of the ardent advocates of tailwheel training drive cars and trucks with automatic transmissions. Well, I'm not an ardent advocate, though I did learn in a taildragger and I continue to fly one. And I have always driven a standard transmission. all the best -- Dan Ford email: (put Cubdriver in subject line) The Warbird's Forum www.warbirdforum.com The Piper Cub Forum www.pipercubforum.com Viva Bush! blog www.vivabush.org |
![]() "Cub Driver" wrote in message ... On Wed, 19 May 2004 13:21:03 -0500, "Bill Denton" wrote: I think it's probably a safe bet that most of the ardent advocates of tailwheel training drive cars and trucks with automatic transmissions. Well, I'm not an ardent advocate, though I did learn in a taildragger and I continue to fly one. And I have always driven a standard transmission. Elitist bigot! :~) (Stuck with Auto Trans due to a wife with three left feet) |
In article , G.R. Patterson III wrote:
You need to learn the proper attitude for whatever aircraft you fly. Learning to land a Cessna 170 will not improve your landings in a 182. Learning to land a 182 will. Having flown both, I'd have to disagree with that. The landing technique to three-point a C170 works great in a C182. Airspeeds are different, but that's it really. -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
Learning to land a Cessna 170 will not improve your landings in a 182. Learning to land a 182 will. George Patterson I whole-heartedly agree with this statement. I got my tailwheel endorsement in my husband's Luscombe 8A. I flew it 70 hours before I bought my own 8E. I tried to fly Lester like his 8A and it didn't work! Once I understood that my airplane had it's own set of peculiar characteristics, things settled down. I do believe that tailwheel training does help a pilot understand the meaning of straight. Flying the Luscombes improved my landings in my C-172. Deb -- 1946 Luscombe 8A (His) 1948 Luscombe 8E (Hers) 1954 Cessna 195B, restoring (Ours) Jasper, Ga. (JZP) |
WINGS: When do the clocks start ticking? | Andrew Gideon | Piloting | 6 | February 3rd 04 03:01 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 12:14 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
