Speaking of Gasoline
Old May 20th 04, 01:40 AM
Newps
"MikeM" wrote in message
The reason that I dont have problems with my boat, truck and airplanes is
that they have large, sealed tanks.
Those are all vented, although depending on the year the newer cars vent
into that coffee can looking container under the hood. A small portable
tank is only vented when you open the vent to pour out the gas. Close that
vent and it is airtight.
Old May 21st 04, 12:33 AM
mikem
I was referring to the small tank on my lawnmower, which has a
vent in the gas cap. It will "go bad" in the 8 months that it
sits unused. If I drain it completly, or pour a few oz of
Stabil in it, then it will run ok the next spring...
MikeM
FS : two Augusta gasoline engines John Bartley Home Built 7 June 7th 04 07:27 AM
FS : two Augusta gasoline engines John Bartley Aviation Marketplace 0 June 5th 04 12:10 PM
The answer to the gasoline problem Veeduber Home Built 4 May 22nd 04 08:58 PM
$3.00 a gallon gasoline by summer(read all of this, it just might work) Fastglasair Home Built 8 March 10th 04 12:12 AM
sealing cork float against gasoline - how to... jt Home Built 13 July 18th 03 10:51 PM
