Where can you get empty caulking gun tubes...
Old July 21st 03, 05:38 PM
RobertR237
In article , "Bart D. Hull"
writes:
to dispense vinylester - mill fiber mixture in a even and fast manner to
close out my top wing skins with no leaks in the tanks.
I have heard about using plastic bags with the end cut off but I'm going
to need to move alot of mixture in a short period.
Any suggestions would be appreciated.
Bart D. Hull
Tempe,Arizona
I used plastic cake decorating bags which worked great. Before starting, I
measured the adhesive quantities into plastic cups and set aside the flox to go
into each mix. Had everything ready before mixing the first batch.
I mixed one batch of just adhesive (No flox) and let my wife paint it on the
bond areas to wet them out while I mixed the adhesive/flox batchs. Mixed one
batch at a time, placed the mix into cake decorating bag and used snap-tie to
tie off the top. If you place the cake decorating bag into a tall plastic cup
and open it up it is very easy to pour/scrap the mix into it. I would pour the
mix into the bag, shake it down and tie of the top, Cut the end and lay down a
thick bead on top of the wet adhesive.
It took just the two of us, my wife and I to do the entire wing close out in 40
minutes. I believe this is easier and faster than trying to use the tubes.
Bob Reed
www.kisbuild.r-a-reed-assoc.com (KIS Builders Site)
KIS Cruiser in progress...Slow but steady progress....
"Ladies and Gentlemen, take my advice,
pull down your pants and Slide on the Ice!"
(M.A.S.H. Sidney Freedman)
Old July 22nd 03, 12:15 AM
Bart Hull
Bob,
Hadn't thought about how to fill the cartridges. (That's another helpers
job right?) I like the idea of the zip lock bags but would prefer the
consistency to be thicker than I can push easily. I always make quite
the mess with a "bakery bag" and end up pushing stuff out the top.
Thanks for the advice.
Bart D. Hull
Tempe,Arizona
Check
http://www.inficad.com/~bdhull/engine.html for my Subaru Engine
Conversion
Check http://www.inficad.com/~bdhull/fuselage.html for Tango II I'm
building.
writes:
Bart D. Hull
Tempe,Arizona
Bob Reed
Bart D. Hull
Tempe,Arizona
Check
Conversion
building.
Old July 22nd 03, 02:15 AM
RobertR237
In article , Bart Hull
writes:
Bob,
I used to have the same problem with the cake bags. I couldn't hold the top
tight enough while squeezing and some of the mix would always squeeze out. I
finally tried twisting the top and using some of those plastic zip-ties to
close it off. Works great and nothing comes out the top.
Bob Reed
