David CL Francis wrote:
Good point. I believe there are some 600 known crash sites in the North of England where aircraft are believed to have flown into high ground during WW2. Around 1 in 5 Spitfire and Hurricane losses were due to accidents and not enemy action if my memory is correct. I read somewhere about bomber squadrons forming up in low vis before a raid. Often the crews wouldn't see the conflicting plane, but they'd feel the wake turbulence and then realized that they'd survived another near miss. All the best, David |
On Mon, 24 May 2004 19:46:05 GMT, David Megginson
wrote: I read somewhere about bomber squadrons forming up in low vis before a raid. Often the crews wouldn't see the conflicting plane, but they'd feel the wake turbulence and then realized that they'd survived another near miss. I don't think they formed up in the clouds Dave. The British would take off and basically head for the target in one huge stream. Bomber Command accepted that some midair collisions would occur but the main point was to pull the bombers together in a swarm to overwhelm the fighter defenses by pushing too many targets for them to track efficiently. There weren't that many German night fighters so if the entire bomber swarm passed through the sector together, the night fighter would not get an opportunity to attack multiple targets. They basically took off, headed for an assembly point and turned for the target when they reached it. The Americans formed up during the day, often climbing out through dense cloud (bomber pilots often said "when heading back to base, head for the biggest cloud in the sky, England will be below it) and breaking out on top to circle for an hour before forming up in wings and groups all the time gaining height before heading towards their target of the day. Sometimes bad things happened in the clouds, sometimes bad things happened in the clear. I have a book at home that has a photo of a group of B-24's headed straight for the nose of the B-17 from where the photo was taken. Someone was out of place in the crowded sky and two entire squadrons of heavy bombers passed right through each other head on. No collisions that time, but there must have been a few tightly puckered pilots. Corky Scott |
There weren't that many German night fighters so if the entire bomber swarm passed through the sector together, the night fighter would not get an opportunity to attack multiple targets. They basically took off, headed for an assembly point and turned for the target when they reached it. You sure about that? I thought the Brit bombers attacked in a "bomber stream" rather than any kind of group formation. -- Dan C172RG at BFM |
Dan Luke wrote:
There weren't that many German night fighters so if the entire bomber swarm passed through the sector together, the night fighter would not get an opportunity to attack multiple targets. They basically took off, headed for an assembly point and turned for the target when they reached it. You sure about that? I thought the Brit bombers attacked in a "bomber stream" rather than any kind of group formation. I'm not sure about the British, but the American bombers flying out of the UK used a box formation -- I think it was three levels high -- and that requires a fair bit of choreography to set up. In any case, there are many gradations of visibility between inside a cloud and severe clear. In THE FOG OF WAR, Robert McNamara talks about how he worked as a statistician for General Curtis LeMay when LeMay was in charge of the Flying Fortresses out of the U.K. in 1943. After having too many planes abort missions because of faulty oxygen systems, engine problems, etc. LeMay (according to McNamara) declared that the next crew who turned back for any reason would be court-martialed. That's a strong disincentive for turning back just because the visibility is low. All the best, David |
![]() "David Megginson" wrote in message e.rogers.com... I'm not sure about the British, but the American bombers flying out of the UK used a box formation -- I think it was three levels high -- and that requires a fair bit of choreography to set up. In any case, there are many gradations of visibility between inside a cloud and severe clear. In THE FOG OF WAR, Robert McNamara talks about how he worked as a statistician for General Curtis LeMay when LeMay was in charge of the Flying Fortresses out of the U.K. in 1943. After having too many planes abort missions because of faulty oxygen systems, engine problems, etc. LeMay (according to McNamara) declared that the next crew who turned back for any reason would be court-martialed. That's a strong disincentive for turning back just because the visibility is low. All the best, David Pour engourage les autres... Jay B |
On Tue, 25 May 2004 00:03:40 GMT, David Megginson
wrote: In THE FOG OF WAR, Robert McNamara talks about This video has been recommended to me. Is it worth seeing? (I'm not interested in a Michael Moore screed. I get all that stuff I can stand on the local cocktail party circuit.) all the best -- Dan Ford email: (put Cubdriver in subject line) The Warbird's Forum www.warbirdforum.com The Piper Cub Forum www.pipercubforum.com Viva Bush! blog www.vivabush.org |
Cub Driver wrote:
In THE FOG OF WAR, Robert McNamara talks about This video has been recommended to me. Is it worth seeing? (I'm not interested in a Michael Moore screed. I get all that stuff I can stand on the local cocktail party circuit.) Yes, THE FOG OF WAR is the kind of documentary that *should* have won a Palme d'Or. Try to see it in a theatre if you can -- I was trembling when I walked out, and I'm not easily moved or impressed by documentaries. All the best, David |
Thanks, David. I'll put it in the queue
![]() On Tue, 25 May 2004 13:00:52 GMT, David Megginson wrote: Cub Driver wrote: In THE FOG OF WAR, Robert McNamara talks about This video has been recommended to me. Is it worth seeing? (I'm not interested in a Michael Moore screed. I get all that stuff I can stand on the local cocktail party circuit.) Yes, THE FOG OF WAR is the kind of documentary that *should* have won a Palme d'Or. Try to see it in a theatre if you can -- I was trembling when I walked out, and I'm not easily moved or impressed by documentaries. All the best, David all the best -- Dan Ford email: (put Cubdriver in subject line) The Warbird's Forum www.warbirdforum.com The Piper Cub Forum www.pipercubforum.com |
On Mon, 24 May 2004 16:21:20 -0500, "Dan Luke"
wrote: wrote: There weren't that many German night fighters so if the entire bomber swarm passed through the sector together, the night fighter would not get an opportunity to attack multiple targets. They basically took off, headed for an assembly point and turned for the target when they reached it. You sure about that? I thought the Brit bombers attacked in a "bomber stream" rather than any kind of group formation. -- Dan Please read what I said again Dan. I'm not claiming that they flew a formation, what I said was that they took off and headed for an assembly point, then turned for the target. The bombers all had to head for the assembly point so that the swarm/stream could get into the same flight path. If they did not do this, the bomber stream would be greatly dispersed. Perhaps assembly point is a poor term, use "initial point" or "turn in" point instead and perhaps you'll see what I mean. They did not actually "assemble" at the turning point, they just used it as a navigation aid to locate where they were and turn to the target heading, or the initial navigation point towards their target. Each bomber did this individually and flew individually climbing as they left their airfield. So they weren't forming a formation, not in the sense of the US daylight bombing, they were just arriving at this point and turning to the target. From then on until they had the target in sight, each individual bomber was responsible for it's own navigation. They often could see other bombers in decent weather, and obviously could also see each other being shot down. During the bombing raid on Nuremburg in 1944, the weather was crystal clear above a low cloud layer and the moon was bright. The bombers stuck out like they were flying during the day. The Germans happened to have numerous fighters orbiting several radio beacons directly in the line of flight and once they released the fighters to engage, the German pilots had little trouble finding targets. So bright was the night that the Wild Sau (undirected single seat fighters, as opposed to twin engine radar guided night fighters) figured prominantly in the nights activities. Nearly 100 bombers were shot down. Corky Scott |
![]() The Americans formed up during the day, often climbing out through dense cloud One of the more famous paragraphs that Stephen Ambrose stole from Thomas Childers had to do with this: "Up, up, up he went, until he got above the clouds. No amount of practice could have prepared the pilot and crew for what they encountered--B-24s, glittering like mica, were popping up out of the clouds over here, over there, everywhere." http://www.warbirdforum.com/copycat.htm They may not have FORMED UP in the cloud, but they had plenty of opportunities to collide on their way to the formup. all the best -- Dan Ford email: (put Cubdriver in subject line) The Warbird's Forum www.warbirdforum.com The Piper Cub Forum www.pipercubforum.com Viva Bush! blog www.vivabush.org |
Homebuilt Airplane Crash | Harry O | Home Built | 1 | November 15th 04 03:40 AM |
Bizzare findings of Flight 93 crash in PA on 9-11 | Laura Bush murdered her boy friend | Military Aviation | 38 | April 12th 04 08:10 PM |
AF investigators cite pilot error in fighter crash | Otis Willie | Military Aviation | 0 | January 9th 04 09:55 PM |
Sunday's Crash in LI Sound | Marco Leon | Piloting | 0 | November 5th 03 04:34 PM |
Homemade plane crash | Big John | Home Built | 9 | October 17th 03 06:45 PM |
