![]() "Bob Moore" wrote in message . 6... "Jim Baker" wrote Vince...everyone is entitled to their opinion. I've seen that tape numerous times and I've done and taught several hundred aileron rolls (23 continuous ones once in a T-38) and barrel rolls. The 707 prototype that day over Lake Seattle did not do an aileron roll, it was a barrel roll. He dove, he climbed and he did a constant "speed" roll about a point which is close to the definition of a barrel roll as I can get without a book in front of me. An aileron roll is a roll about the longitudinal axis of the aircraft. He did not do a 360 roll around the longitudinal axis. Vince has it right. You must have missed last year's "barrel-roll discussion", a portion of which is quoted from William Kershner's book "The Flight Instructor's Manual". Do a newsgroup Google search for barrel roll and you will find the entire debate between "Big John" and myself. "How- You might use the following explanation, or develop your own: (1) Make sure the area is clear, then pick a reference on the horizon off the wing tip as in the wingover and lazy eight. (2) Set the throttle to low cruise rpm and ease the nose over to pick- up about 10 K more than used for the wingover or set up the airspeed used for a loop, whichever is higher. Power adjustment should not be necessary during the maneuver. You might have some of your sharper trainees apply full power as the airplane approaches inverted and then remind them to throttle back as the airspeed picks up in the last part of the maneuver. (3) Smoothly pull the nose up and start a coordinated climbing turn (note that it will have to be at a much faster rate than was used for the wingover) toward the reference point. (Assume that at first the roll will be to the left.) (4) When the nose is 45° from the original heading, it should be at its highest pitch attitude and the left bank should be vertical. (5) When the nose is at 90° from the original heading, you should be looking directly at the reference point that was originally off the wing tipfrom a completely inverted position (momentarily). (6) When the airplane heading is again 45° from the original, the bank is vertical but you will be in a right bank as far as the ground is concerned; that is, the right wing is pointing straight down at this instant of roll. The nose will be at its lowest pitch attitude at this point. (7) The roll is continued to wings-level flight as the nose is raised back to the cruise attitude." Note that half-way through the maneuver, the nose of the airplane is 90 degrees to original heading at the same time that the airplane is inverted. Bob Moore This is simply the "classic" method of teaching a barrel roll. A barrel roll is simply a 3 dimensional maneuver, and in fact in air combat maneuvering, is the ONLY 3 dimensional maneuver through 3 dimensional space. The roll can be performed as written by you and Kershner here, or it can be flown much tighter. Any roll that is FLOWN through 3 dimensions while maintaining a positive g on the airplane is a barrel roll. The "barrel" can also be altered while in the roll by changing the load on the airplane.In fact, in one offshoot scenario in the ACM arena, we often began a barrel roll with positive g, then unloaded the airplane to just below ballistic in the roll. (speeds up the roll rate :-) Tex's roll was absolutely a barrel roll. Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt |
![]() "Jim Baker" wrote in message ... "vincent p. norris" wrote in message ... As for what they're capable of, remember Tex Johnson(sp?) barrel rolled the 707 prototype (the "Dash-80"). Actually, an aileron roll, Paul. I know his book, ghost written by another, says barrel roll, but the tape shows it's an aileron roll. Among non-fliers, all rolls are "barrel rolls," just as all loops are "loop-de-loops" and among Southerners, all Northerners are "Damnyankees." vince norris Vince...everyone is entitled to their opinion. I've seen that tape numerous times and I've done and taught several hundred aileron rolls (23 continuous ones once in a T-38) and barrel rolls. The 707 prototype that day over Lake Seattle did not do an aileron roll, it was a barrel roll. He dove, he climbed and he did a constant "speed" roll about a point which is close to the definition of a barrel roll as I can get without a book in front of me. An aileron roll is a roll about the longitudinal axis of the aircraft. He did not do a 360 roll around the longitudinal axis. Regards, JB I almost hate to get into this one again, as the last time was quite unpleasant! :-) It was a barrel roll. The -80 needed positive g all the way around for the oil scavenger pumps. Tex knew this and I discussed it with him many times through the years. Also, the airplane, regardless of how high the roll set would have been and regardless of the airspeed at entry for a pure aileron roll , would not have had the energy available through the roll axis to complete an aileron roll without split S'ing out the back side. The result of a pure aileron input would have been a HUGE split S with serious airspeed problems on the back side!. Tex did the roll the only way the airplane could have been rolled. He FLEW it all the way around the barrel, keeping positive g on the airplane throughout the maneuver for the oil pumps and to avoid the split s. Tex flew the prototype through a 3 dimensional roll at positive g , and that spells barrel roll. All the best as usual, Dudley |
![]() "Dudley Henriques" wrote in message link.net... "Jim Baker" wrote in message ... "vincent p. norris" wrote in message ... As for what they're capable of, remember Tex Johnson(sp?) barrel rolled the 707 prototype (the "Dash-80"). Actually, an aileron roll, Paul. I know his book, ghost written by another, says barrel roll, but the tape shows it's an aileron roll. Among non-fliers, all rolls are "barrel rolls," just as all loops are "loop-de-loops" and among Southerners, all Northerners are "Damnyankees." vince norris Vince...everyone is entitled to their opinion. I've seen that tape numerous times and I've done and taught several hundred aileron rolls (23 continuous ones once in a T-38) and barrel rolls. The 707 prototype that day over Lake Seattle did not do an aileron roll, it was a barrel roll. He dove, he climbed and he did a constant "speed" roll about a point which is close to the definition of a barrel roll as I can get without a book in front of me. An aileron roll is a roll about the longitudinal axis of the aircraft. He did not do a 360 roll around the longitudinal axis. Regards, JB I almost hate to get into this one again, as the last time was quite unpleasant! :-) It was a barrel roll. The -80 needed positive g all the way around for the oil scavenger pumps. Tex knew this and I discussed it with him many times through the years. Also, the airplane, regardless of how high the roll set would have been and regardless of the airspeed at entry for a pure aileron roll , would not have had the energy available through the roll axis to complete an aileron roll without split S'ing out the back side. The result of a pure aileron input would have been a HUGE split S with serious airspeed problems on the back side!. Tex did the roll the only way the airplane could have been rolled. He FLEW it all the way around the barrel, keeping positive g on the airplane throughout the maneuver for the oil pumps and to avoid the split s. Tex flew the prototype through a 3 dimensional roll at positive g , and that spells barrel roll. All the best as usual, Dudley I must have missed last years blood bath, :-)) I don't know how anyone looking at that tape, who has done the manuevers we're speaking of, could confuse one with the other. As you've said Dudley, the -80 (which I had the pleasure of seeing up close on Mothers Day weekend) did not have the roll authority to do an aileron roll. Those little tiny ailerons couldn't provide enough asymetic energy. Half way through the crew would have been looking straight down at Lake WASHINGTON (thanks Pete!). Now maybe that would have been more impressive, but it would've taken one hell of an altitude to start and the folks on the ground might not have been able to even see the entry. I've "aileron" rolled a large aircraft ( 250,000 lbs) a few times but it didn't depend on ailerons for the manuever. The B-1B used a split stab for primary roll authority and that was one huge, split "aileron" that provided enough energy to roll the aircraft without the Split S and the problems that would bring to a large airframe. Have a pleasant weekend fellas!! Stepping off the battlefied, Jim |
![]() "Jim Baker" wrote in message ... "Dudley Henriques" wrote in message link.net... "Jim Baker" wrote in message ... "vincent p. norris" wrote in message ... As for what they're capable of, remember Tex Johnson(sp?) barrel rolled the 707 prototype (the "Dash-80"). Actually, an aileron roll, Paul. I know his book, ghost written by another, says barrel roll, but the tape shows it's an aileron roll. Among non-fliers, all rolls are "barrel rolls," just as all loops are "loop-de-loops" and among Southerners, all Northerners are "Damnyankees." vince norris Vince...everyone is entitled to their opinion. I've seen that tape numerous times and I've done and taught several hundred aileron rolls (23 continuous ones once in a T-38) and barrel rolls. The 707 prototype that day over Lake Seattle did not do an aileron roll, it was a barrel roll. He dove, he climbed and he did a constant "speed" roll about a point which is close to the definition of a barrel roll as I can get without a book in front of me. An aileron roll is a roll about the longitudinal axis of the aircraft. He did not do a 360 roll around the longitudinal axis. Regards, JB I almost hate to get into this one again, as the last time was quite unpleasant! :-) It was a barrel roll. The -80 needed positive g all the way around for the oil scavenger pumps. Tex knew this and I discussed it with him many times through the years. Also, the airplane, regardless of how high the roll set would have been and regardless of the airspeed at entry for a pure aileron roll , would not have had the energy available through the roll axis to complete an aileron roll without split S'ing out the back side. The result of a pure aileron input would have been a HUGE split S with serious airspeed problems on the back side!. Tex did the roll the only way the airplane could have been rolled. He FLEW it all the way around the barrel, keeping positive g on the airplane throughout the maneuver for the oil pumps and to avoid the split s. Tex flew the prototype through a 3 dimensional roll at positive g , and that spells barrel roll. All the best as usual, Dudley I must have missed last years blood bath, :-)) I don't know how anyone looking at that tape, who has done the manuevers we're speaking of, could confuse one with the other. As you've said Dudley, the -80 (which I had the pleasure of seeing up close on Mothers Day weekend) did not have the roll authority to do an aileron roll. Those little tiny ailerons couldn't provide enough asymetic energy. Half way through the crew would have been looking straight down at Lake WASHINGTON (thanks Pete!). Now maybe that would have been more impressive, but it would've taken one hell of an altitude to start and the folks on the ground might not have been able to even see the entry. I've "aileron" rolled a large aircraft ( 250,000 lbs) a few times but it didn't depend on ailerons for the manuever. The B-1B used a split stab for primary roll authority and that was one huge, split "aileron" that provided enough energy to roll the aircraft without the Split S and the problems that would bring to a large airframe. Have a pleasant weekend fellas!! Stepping off the battlefied, Jim Biggest thing I ever barreled was a twin Beech. The B1 had to be a handful!! Watched a buddy of mine in the RAF barrel a Vulcan once. Beautiful!! You should have seen that bat winged SOB going around. His nose had to be sixty degrees as he initiated. Last word I got from the Blues was that the boss had to come out to the ramp every morning and tell the Fat Albert crew, "You will NOT roll this airplane today gentlemen. I don't give a **** HOW much money the diamond has paid you to try it" :-)))) Dudley |
And in a true aileron roll you pull one negative G to hold the point while
inverted. A little tough with an air carrier machine. -- B-58 Hustler History: http://members.cox.net/dschmidt1/ - I don't know how anyone looking at that tape, who has done the manuevers we're speaking of, could confuse one with the other. As you've said Dudley, the -80 (which I had the pleasure of seeing up close on Mothers Day weekend) did not have the roll authority to do an aileron roll. Those little tiny ailerons couldn't provide enough asymetic energy. Half way through the crew would have been looking straight down at Lake WASHINGTON (thanks Pete!). Now maybe that would have been more impressive, but it would've taken one hell of an altitude to start and the folks on the ground might not have been able to even see the entry. I've "aileron" rolled a large aircraft ( 250,000 lbs) a few times but it didn't depend on ailerons for the manuever. The B-1B used a split stab for primary roll authority and that was one huge, split "aileron" that provided enough energy to roll the aircraft without the Split S and the problems that would bring to a large airframe. Have a pleasant weekend fellas!! Stepping off the battlefied, Jim |
"Darrell" wrote
And in a true aileron roll you pull one negative G to hold the point while inverted. Darrell, how come you Air Force guys define rolls differently than everyone else? http://acro.harvard.edu/ACRO/acro_figures.html#rolls Aileron rolls are flown with the rudder and elevator in the neutral position during the roll. The aileron is fully deflected in the direction of the roll. This is the easiest of the rolls to fly. The aileron roll is started by pulling the nose up to 20 - 30 degrees above the horizon. The elevator is then neutralized and the aileron fully deflected in the direction of the roll. The controls are maintained in that position till the roll is completed. After the roll is completed the nose is usually 20 - 30 degrees below the horizon. Slow rolls have to be flown normally on a straight line. The roll rate has to be constant and the longitudinal axis of the plane has to go straight. This requires constantly changing rudder and elevator control inputs throughout the roll. Hesitation or point rolls include stops at certain roll angles. ------------------------------------------------------------ http://www.sunrise-aviation.com/Ailroll.html As the name implies, the aileron roll is done with "normal" inputs of aileron and rudder (in contrast to snap rolls). At the point this maneuver is introduced to students in the Sunrise Basic syllabus, no attempt is made to maintain altitude during the roll. The result is a steady transition from climb to descent until the aircraft regains upright flight. This simplified approach to rolling is ideal for beginning aerobatic pilots. A further development of basic rolling technique introduces forward elevator (and negative G) to eliminate altitude loss while inverted. The result is a Slow Roll, introduced in the Sunrise Intermediate syllabus. Once mastered, slow rolls completely replace aileron rolls in the repertoires of most pilots. ---------------------------------------------------------------- Bob Moore |
According to the Smithsonian it was a barrel roll.
Margy "vincent p. norris" wrote: As for what they're capable of, remember Tex Johnson(sp?) barrel rolled the 707 prototype (the "Dash-80"). Actually, an aileron roll, Paul. I know his book, ghost written by another, says barrel roll, but the tape shows it's an aileron roll. Among non-fliers, all rolls are "barrel rolls," just as all loops are "loop-de-loops" and among Southerners, all Northerners are "Damnyankees." vince norris |
Boeing Boondoggle | Larry Dighera | Military Aviation | 77 | September 15th 04 02:39 AM |
Boeing 757 turn rate? | Garyurbach | Aerobatics | 6 | June 14th 04 04:43 PM |
Boeing 757 turn rate? | Garyurbach | Military Aviation | 1 | June 7th 04 05:48 PM |
763 Cruising Speed. | [email protected] | General Aviation | 24 | February 9th 04 09:30 PM |
