"Jim Baker" wrote
Vince...everyone is entitled to their opinion. I've seen that tape numerous times and I've done and taught several hundred aileron rolls (23 continuous ones once in a T-38) and barrel rolls. The 707 prototype that day over Lake Seattle did not do an aileron roll, it was a barrel roll. He dove, he climbed and he did a constant "speed" roll about a point which is close to the definition of a barrel roll as I can get without a book in front of me. An aileron roll is a roll about the longitudinal axis of the aircraft. He did not do a 360 roll around the longitudinal axis. Vince has it right. You must have missed last year's "barrel-roll discussion", a portion of which is quoted from William Kershner's book "The Flight Instructor's Manual". Do a newsgroup Google search for barrel roll and you will find the entire debate between "Big John" and myself. "How- You might use the following explanation, or develop your own: (1) Make sure the area is clear, then pick a reference on the horizon off the wing tip as in the wingover and lazy eight. (2) Set the throttle to low cruise rpm and ease the nose over to pick- up about 10 K more than used for the wingover or set up the airspeed used for a loop, whichever is higher. Power adjustment should not be necessary during the maneuver. You might have some of your sharper trainees apply full power as the airplane approaches inverted and then remind them to throttle back as the airspeed picks up in the last part of the maneuver. (3) Smoothly pull the nose up and start a coordinated climbing turn (note that it will have to be at a much faster rate than was used for the wingover) toward the reference point. (Assume that at first the roll will be to the left.) (4) When the nose is 45° from the original heading, it should be at its highest pitch attitude and the left bank should be vertical. (5) When the nose is at 90° from the original heading, you should be looking directly at the reference point that was originally off the wing tipfrom a completely inverted position (momentarily). (6) When the airplane heading is again 45° from the original, the bank is vertical but you will be in a right bank as far as the ground is concerned; that is, the right wing is pointing straight down at this instant of roll. The nose will be at its lowest pitch attitude at this point. (7) The roll is continued to wings-level flight as the nose is raised back to the cruise attitude." Note that half-way through the maneuver, the nose of the airplane is 90 degrees to original heading at the same time that the airplane is inverted. Bob Moore |
![]() "Bob Moore" wrote in message . 6... "Jim Baker" wrote Vince...everyone is entitled to their opinion. I've seen that tape numerous times and I've done and taught several hundred aileron rolls (23 continuous ones once in a T-38) and barrel rolls. The 707 prototype that day over Lake Seattle did not do an aileron roll, it was a barrel roll. He dove, he climbed and he did a constant "speed" roll about a point which is close to the definition of a barrel roll as I can get without a book in front of me. An aileron roll is a roll about the longitudinal axis of the aircraft. He did not do a 360 roll around the longitudinal axis. Vince has it right. You must have missed last year's "barrel-roll discussion", a portion of which is quoted from William Kershner's book "The Flight Instructor's Manual". Do a newsgroup Google search for barrel roll and you will find the entire debate between "Big John" and myself. "How- You might use the following explanation, or develop your own: (1) Make sure the area is clear, then pick a reference on the horizon off the wing tip as in the wingover and lazy eight. (2) Set the throttle to low cruise rpm and ease the nose over to pick- up about 10 K more than used for the wingover or set up the airspeed used for a loop, whichever is higher. Power adjustment should not be necessary during the maneuver. You might have some of your sharper trainees apply full power as the airplane approaches inverted and then remind them to throttle back as the airspeed picks up in the last part of the maneuver. (3) Smoothly pull the nose up and start a coordinated climbing turn (note that it will have to be at a much faster rate than was used for the wingover) toward the reference point. (Assume that at first the roll will be to the left.) (4) When the nose is 45° from the original heading, it should be at its highest pitch attitude and the left bank should be vertical. (5) When the nose is at 90° from the original heading, you should be looking directly at the reference point that was originally off the wing tipfrom a completely inverted position (momentarily). (6) When the airplane heading is again 45° from the original, the bank is vertical but you will be in a right bank as far as the ground is concerned; that is, the right wing is pointing straight down at this instant of roll. The nose will be at its lowest pitch attitude at this point. (7) The roll is continued to wings-level flight as the nose is raised back to the cruise attitude." Note that half-way through the maneuver, the nose of the airplane is 90 degrees to original heading at the same time that the airplane is inverted. Bob Moore This is simply the "classic" method of teaching a barrel roll. A barrel roll is simply a 3 dimensional maneuver, and in fact in air combat maneuvering, is the ONLY 3 dimensional maneuver through 3 dimensional space. The roll can be performed as written by you and Kershner here, or it can be flown much tighter. Any roll that is FLOWN through 3 dimensions while maintaining a positive g on the airplane is a barrel roll. The "barrel" can also be altered while in the roll by changing the load on the airplane.In fact, in one offshoot scenario in the ACM arena, we often began a barrel roll with positive g, then unloaded the airplane to just below ballistic in the roll. (speeds up the roll rate :-) Tex's roll was absolutely a barrel roll. Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt |
Boeing Boondoggle | Larry Dighera | Military Aviation | 77 | September 15th 04 02:39 AM |
Boeing 757 turn rate? | Garyurbach | Aerobatics | 6 | June 14th 04 04:43 PM |
Boeing 757 turn rate? | Garyurbach | Military Aviation | 1 | June 7th 04 05:48 PM |
763 Cruising Speed. | [email protected] | General Aviation | 24 | February 9th 04 09:30 PM |
