Redline (formerly the Beater thread)
Old June 14th 04, 06:28 PM
Jay Honeck
Why would (just for example) shortening the prop allow one to raise the
RPM
limit of the engine?
It's bad to allow the prop tip to go supersonic.
Understood.
However, how is it that you can up the RPM limit of a given engine simply
because you want to keep the prop tips subsonic?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old June 14th 04, 07:41 PM
Jay Masino
You would decrease the RPM limit, not increase it, to keep the tips
subsonic.
__!__
Jay and Teresa Masino ___(_)___
http://www2.ari.net/jmasino ! ! !
http://www.oceancityairport.com
http://www.oc-adolfos.com
Old June 14th 04, 08:39 PM
Jay Honeck
simply
subsonic.
Understood. If you lengthened the prop, you'd have to decrease the RPM
redline to keep the tips subsonic.
However, the part of the question I was referring to was if you *shortened*
the prop. Part of the original post implied that you would be able to
simply *increase* the engine's redline RPM if you shortened your prop,
regardless of engine limitations. I don't believe this is true.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old June 14th 04, 09:44 PM
Richard Russell
On Mon, 14 Jun 2004 19:39:46 GMT, "Jay Honeck"
simply
subsonic.
It isn't true. Theoretically, you could increase the redline rpm
providing you don't exceed the limitations of any other part of the
"system", such as the engine. The redline would have to be based upon
the most restrictive component.
Rich Russell
Old June 14th 04, 11:45 PM
EDR
Found the source, sort of...
http://www.airweb.faa.gov/Regulatory...rgAdvisoryCirc
ular.nsf/0/c2f903127f0f41e4862569ae006d44d7/$FILE/AC20-88A.pdf
ANNOUNCEMENT OF AVAILABILITY OF ADVISORY CIRCULAR 20-88A; LINES ON THE
MARKING OF AIRCRAFT POWERPLANT INSTRUMENTS (DISPLAYS)
g. Tachometer (Reciprocating Engine Aircraft)
Red Radial - At maximum permissible rotational speed (rpm).
Green Arc - From maximum rotational speed for continuous operation to
minimum recommended for continuous operation (except in the restricted
range, if any). For propeller driven small airplanes which must meet
the requirements in Appendix F to Part 36 of the FAR at maximum normal
operating power, from the corrected rotational speed used to establish
the aircraft noise level to the minimum recommended for continuous
operation (except in the restricted ranges, if any).
Yellow Arc - From maximum rotational speed for continuous operation to
maximum permissible rotational speed.
Yellow Arc (Offset) - Conditional operating range for one engine
inoperative flight that exists above the normal takeoff rating limit
(if applicable).
Red Arc - Range(s) in which operation is restricted, except to pass
through, for all operating conditions because of excessive stresses,
etc.
Old June 15th 04, 12:18 AM
Jay Masino
I think at that point, you'd be getting into limitations of the engine
components (with some tolerance).
__!__
Are You Flying a "Beater?" Jay Honeck Piloting 90 June 16th 04 11:38 AM
Contract Tower Program - Discussion Thread running with scissors Instrument Flight Rules 6 April 22nd 04 04:04 AM
Baby Bush will be Closing Airports in California to VFR Flight Again Larry Dighera Piloting 119 March 13th 04 02:56 AM
Fuel line thread sealant Paul Lee Home Built 7 February 26th 04 12:44 AM
recovery from inverted IMC (a propos of "backup gyros" thread) Sydney Hoeltzli Piloting 4 July 15th 03 02:00 PM
