Could it have possibly been gusts hitting the prop? This would give the
deceleration and some changes in sound, similar to what you describe-at least with the prop out front. Was it a gusty or thermally day? A little thermal turbulence will hit the prop from all kinds of angles changing its sound. I always look for the simplest (and cheapest) explanations first. mike regish "Peter Duniho" wrote in message ... Well, we'd only climbed a few hundred feet when something in the airplane started making a very strange noise. My friend's wife heard it too. It was sort of a rapid "growling" sound, lasting a second or two at a time, with maybe five or ten seconds between. It seemed most likely to be coming from the engine, but it was subtle enough I couldn't rule out some sort of airframe flutter. It might have been my imagination, but it seemed like whenever I heard the sound, there was a little deceleration from the airplane. |
"mike regish" wrote in message
news:37nzc.30974$2i5.23228@attbi_s52... Could it have possibly been gusts hitting the prop? This would give the deceleration and some changes in sound, similar to what you describe-at least with the prop out front. Was it a gusty or thermally day? Nope, that's not it. It was a little windy that day, but the sound was far too regular to be any sort of response to wind gusts. Also, I've got plenty of experience flying this airplane in a wide variety of wind conditions, including much stronger gusts and winds than existed on this flight, and have never experienced any sound like this as a result. [...] I always look for the simplest (and cheapest) explanations first. Me too. I'm still hoping for that. But there are a number of "simplest" explanations I can definitely rule out. ![]() I just heard from my mechanic. He wasn't able to make it over to the airplane today, but says he should be able to get to it tomorrow morning. He's going to inspect the airframe and engine, do some full-power run-ups to see if he can reproduce the sound on the ground. Hopefully I'll know something more after that. Anyone have any thoughts on what to do if nothing is found? I figure at some point, a decision will need to be made as to whether to give up and completely dismantle the engine, or to just go fly it again to see if the problem can be reproduced. With my mechanic on board, of course, so he can hear the noise first-hand. As an intermediate step, it occurs to me that even though the oil was just changed, we could change it again, and inspect the filter to see if there's any metal. Presumably if the engine truly were on the verge of coming apart, it'd be shedding at least some metal into the oil, right? Or wrong? I'll be running that question past my mechanic as well, but I figure when looking for opinions, this is a great place to ask. ![]() Pete |
On Mon, 14 Jun 2004 16:49:49 -0700, "Peter Duniho"
wrote in Message-Id: : I just heard from my mechanic. He wasn't able to make it over to the airplane today, but says he should be able to get to it tomorrow morning. He's going to inspect the airframe and engine, do some full-power run-ups to see if he can reproduce the sound on the ground. I would suggest that you attend his inspection, and take a mechanic's stethoscope with you. That way you'll know what he did and did not check, and can delve a little deeper into the issue. Someone with a personal interest and a keen sense of concern can often suggest relevant procedures beyond those of an average A&P. At least you'll be able to watch the gages while he runs it up. I have had experienced mechanics completely overlook subtle nuances of anomalous behavior that only the owner, who regularly experiences the machine in its nominal state, can readily discern. -- Irrational beliefs ultimately lead to irrational acts. -- Larry Dighera, |
![]() Peter Duniho wrote: Presumably if the engine truly were on the verge of coming apart, it'd be shedding at least some metal into the oil, right? Or wrong? Probably not. While there are a few problems that will shed metal particles into the oil (a disintegrating bearing, for example), most will not. For example, a valve that's beginning to stick will not. George Patterson None of us is as dumb as all of us. |
... Nope, that's not it. It was a little windy that day, but the sound was far too regular to be any sort of response to wind gusts. Anyone have any thoughts on what to do if nothing is found? As an intermediate step, it occurs to me that even though the oil was just changed, Did the plane just have an inspection? Was the fuel filter/gascolator inspected/cleaned? Whenever my plane just comes out of an annual I have to run it for a bit to get the air out of the fuel lines. Can also be bubbles when it's hot but I guess you know that. Usually disappears by the time I complete the run-up, but if I were quick I guess I could take it into the air. Paul |
"Paul Sengupta" wrote in message
... Did the plane just have an inspection? [...] Define "just". It did recently come out of its annual inspection. However, it'd had four flights already since the inspection and before the flight on which this happened. Also, this is the eleventh annual inspection since I purchased the airplane, so if air in the fuel lines were a normal post-annual-inspection thing, I'd think that I'd have seen that before. I can't rule out fuel contamination, just as I can't rule out many other things. But the one time I had water (not air) in the fuel, the power loss I experienced was greater than, and rougher than, what I experienced this time. So I'm inclined to think it wasn't that. Pete |
... "Paul Sengupta" wrote in message ... Did the plane just have an inspection? [...] Define "just". It did recently come out of its annual inspection. However, it'd had four flights already since the inspection and before the flight on which this happened. Ah, then I guess not. It's just the first time I start the engine after the annual that it happens on my plane. Just an idea. Paul |
engine trouble | mindenpilot | Owning | 16 | February 10th 05 02:17 AM |
ROP masking of engine problems | Roger Long | Owning | 4 | September 27th 04 07:36 PM |
Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 06:42 PM |
Real stats on engine failures? | Captain Wubba | Piloting | 127 | December 8th 03 04:09 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
