![]() "John Bell" wrote in message om... From: "Richard Hertz" I have yet to try this myself, but two pilots I know suggested I try it. The airways are defined by VOR radials. GPSs do not seem to navigate them correctly. In fact, one of the pilots mentioned flew with an "instructor" who was relying on a GPS for lateral guidance on an IFR flight plan. The pilot told the instructor to knock it off and use the vors as he was seeing CDI needle deflection. The instructor said not to worry. After some time ATC informed them that they were off the airway (though the gps showed dead-on). You should be able to navigate an airway more accurately using a GPS than you can with a VOR. You should be able to navigate using no GPS. Today there seems to be a reliance on pretty pictures to tell us where we are. The trouble with that is when the picture goes blank, or when the GPS does not put us on the airway. "Should" and what happens in reality are different things. No amount of theory or web links are going to convince the FAA or a controller that you were not on their airway when you should have been. The problem with VORs is that they are not aligned with magnetic north. Usually, they are aligned with magnetic north when the VOR station is first installed, but they are not kept in alignment as the earth's magnetic field shifts. Have you ever noticed how runways are occasionally recharted with new magnetic headings? Also check he http://www.geolab.nrcan.gc.ca/geomag...vt_nmp_e.shtml. Many GPS receivers use a model of the earth's magnetic field that results in a magnetic correction similar to the isogonic lines on the chart. If the instructor executed a direct to the VOR waypoint in the GPS and then used the OBS feature to select the inbound course as depicted by the VOR radial on the chart, he may be several degrees off. If you want to look at an example, go to www.airnav.com and pull up SWL VOR and KOXB (Ocean City). SWL has a variation of 8W (1965) and KOXB has a variation of 12W (2000). There might be a close airport, but SWL is 22 nm from KOXB. Some GPS receivers such as the Garmin 196, 295, 296, 430, and 530 use the slaved value of the VOR for the OBS mode. Thus, setting the OBS mode to a value results in the same path over the ground as if you selected the VOR OBS to the same number. On some GPS receivers, such as the Garmin GPS III Pilot the GPS does not compensate for this VOR misalignment. What I don't know is whether there is any requirement for an IFR certified GPS to use the VOR slaved value for magnetic variation. There is also the possibility that the instructor in your story was using a non-IFR GPS. This is not to say the OBS mode is the best way to navigate an airway, just that this might be a cause for error. A better way is to set up a route in the GPS to reflect points on the airway. Such as from VOR A to VOR B or INTERSECTION to VOR if there is a bend in the airway. John Bell www.cockpitgps.com |
Amateur Review of the Garmin GPSMAP 296 GPS | Rhett | Piloting | 10 | March 23rd 05 01:16 AM |
Garmin 296 worth the money? | Terry | Owning | 15 | June 22nd 04 09:03 AM |
Microsoft Flight Simulator and Garmin aviation handheld GPS | John Bell | Piloting | 4 | March 25th 04 11:56 AM |
Garmin DME arc weidnress | Dave Touretzky | Instrument Flight Rules | 5 | October 2nd 03 02:04 AM |
Garmin 90 Database Updates Discontinued | Val Christian | Piloting | 14 | August 20th 03 09:32 PM |
