Oil leak
Old June 21st 04, 04:08 PM
Bob Moore
"G.R. Patterson III" wrote
mike regish wrote:
I have a 1/4-20 bottom
tap I'm going to run in to clean up the threads.
One more thing you've probably already thought of. Most taps have a
tapered tip. When used as a chaser, such a tap will not clean the
bottom threads in a hole. You can take care of this by cutting and/or
grinding most of the tapered section off the end of the tap.
Well, let's see.... he did say that he has a "bottom" tap.
Bob Moore
Old June 21st 04, 08:25 PM
mike regish
Problem found-not solved yet. The ears where the bolts go through the
housing are cracked. Must've been growing for a while. I saw some suspicious
lines yesterday, but thought they were just in the paint. After cleaning up
all the threads and replacing the screen adn housing I ran it up at idle.
Oil-still leaking. I could also very clearly see the cracks. Anybody know
where I can get an oil screen housing?
mike regish
"Bob Moore" wrote in message
. 6...
Bob Moore
Old June 22nd 04, 02:18 AM
G.R. Patterson III
Ah! Missed that. No need to jerry-rig one, then.
George Patterson
None of us is as dumb as all of us.
Old June 22nd 04, 03:46 AM
mike regish
Actually, I ground off the first 4 threads because they looked pretty dull
anyways.
So...Stop! You're both right!
mike regish
"G.R. Patterson III" wrote in message
George Patterson
Oil Leak on top of the engine -- follow up Jay Honeck Owning 6 February 13th 05 01:50 PM
Oil leak on top of the engine Jay Honeck Owning 31 February 12th 05 02:27 AM
oil leak question Dick Home Built 18 November 19th 04 03:14 PM
~ DICK GRILLED FOR CIA LEAK - CAN YOU SAY PRISON?! ~ ~ THE CHOKING CHIMP ~ Military Aviation 0 June 6th 04 05:34 AM
oil leak fixed - breaking in new cylinders Michael 182 Owning 24 September 23rd 03 12:36 PM
