Andrew Gideon wrote in
online.com: What type of flight plan is required? Composite (IFR through class A, VFR above)? Does Center provide services at these altitudes, or does one fall back on reporting points? - Andrew Was a TFR established around the launch site? |
"Andrew Sarangan" wrote in message
. 158... Andrew Gideon wrote in online.com: What type of flight plan is required? Composite (IFR through class A, VFR above)? Does Center provide services at these altitudes, or does one fall back on reporting points? - Andrew Was a TFR established around the launch site? Yup |
. 158... Andrew Gideon wrote in online.com: What type of flight plan is required? Composite (IFR through class A, VFR above)? Does Center provide services at these altitudes, or does one fall back on reporting points? - Andrew Was a TFR established around the launch site? If I remember correctly, it was 7mi radius centered on KMHV up to FL200. And isn't airspace above FL600 in the US class E? Why the need for a change at that altitude? |
![]() "Tony Cox" wrote in message link.net... And isn't airspace above FL600 in the US class E? Yes. Why the need for a change at that altitude? Well, above some level there's just no need for it to be Class A anymore. The level decided upon was FL 600. |
ink.net... "Tony Cox" wrote in message link.net... And isn't airspace above FL600 in the US class E? Yes. Why the need for a change at that altitude? Well, above some level there's just no need for it to be Class A anymore. The level decided upon was FL 600. Yes, but surely an IFR flight plan would be just as valid when ascending through FL600 as when descending below FL180. Assuming the mode C is properly calibrated, that is. |
![]() "Tony Cox" wrote in message ink.net... Yes, but surely an IFR flight plan would be just as valid when ascending through FL600 as when descending below FL180. Absolutely, in each case you're leaving Class A airspace and entering Class E airspace. Assuming the mode C is properly calibrated, that is. The IFR flight plan is just as valid with an improperly calibrated encoder. I worked a flight above FL600 just once. About fifteen years ago I was a controller at Chicago Center working traffic in the Madison, WI, area. A NASA ER-1 departed MSN requesting an unrestricted climb to FL610. I coordinated with the high altitude sector and issued the climb. He went up like a rocket! The Mode C readout couldn't keep up with him. Shortly after he reported out of FL600 and cancelled IFR, the Mode C read FL600. I asked a Data Systems Specialist about it and he told me that FL600 and higher will read out as FL600. |
![]() "Steven P. McNicoll" wrote in message ink.net... I worked a flight above FL600 just once. About fifteen years ago I was a controller at Chicago Center working traffic in the Madison, WI, area. A NASA ER-1 departed MSN requesting an unrestricted climb to FL610. What's an ER-1? I coordinated with the high altitude sector and issued the climb. He went up like a rocket! The Mode C readout couldn't keep up with him. Shortly after he reported out of FL600 and cancelled IFR, the Mode C read FL600. I asked a Data Systems Specialist about it and he told me that FL600 and higher will read out as FL600. Cool!!! |
![]() "Tom Sixkiller" wrote in message ... What's an ER-1? At the time, it was a derivitive of the Lockheed TR-1, which has since been redesignated U-2R. |
ink.net... Assuming the mode C is properly calibrated, that is. How do you measure altitude at 328k feet? Surely a standard barometric device isn't going to work? Paul |
"Paul Sengupta" wrote in message
... "Tony Cox" wrote in message ink.net... Assuming the mode C is properly calibrated, that is. How do you measure altitude at 328k feet? Surely a standard barometric device isn't going to work? Paul Below about 50 milliBar, people use a Pirani Gauge, which is essentially a broken light bulb -- the wire gets hotter & changes electrical resistance as there is less air to cool the wire. 50mBar is around 75K ft. Lower than about 10-2 milliBar, Ion gauges are the way to go. They are like broken vacuum tubes. |
Did the Germans have the Norden bombsight? | Cub Driver | Military Aviation | 106 | May 12th 04 07:18 AM |
Hubble plug to be pulled | John Carrier | Military Aviation | 33 | March 19th 04 04:19 AM |
Rules on what can be in a hangar | Brett Justus | Owning | 13 | February 27th 04 05:35 PM |
OT (sorta): Bush Will Announce New Space Missions | Dav1936531 | Military Aviation | 0 | January 9th 04 10:34 AM |
Strategic Command Missions Rely on Space | Otis Willie | Military Aviation | 0 | September 30th 03 09:59 PM |
