![]() "Tony Cox" wrote in message ink.net... "Paul Sengupta" wrote in message How do you measure altitude at 328k feet? Surely a standard barometric device isn't going to work? Paul Below about 50 milliBar, people use a Pirani Gauge, which is essentially a broken light bulb -- the wire gets hotter & changes electrical resistance as there is less air to cool the wire. 50mBar is around 75K ft. Lower than about 10-2 milliBar, Ion gauges are the way to go. They are like broken vacuum tubes. Ah, thanks! Paul |
Did the Germans have the Norden bombsight? | Cub Driver | Military Aviation | 106 | May 12th 04 07:18 AM |
Hubble plug to be pulled | John Carrier | Military Aviation | 33 | March 19th 04 04:19 AM |
Rules on what can be in a hangar | Brett Justus | Owning | 13 | February 27th 04 05:35 PM |
OT (sorta): Bush Will Announce New Space Missions | Dav1936531 | Military Aviation | 0 | January 9th 04 10:34 AM |
Strategic Command Missions Rely on Space | Otis Willie | Military Aviation | 0 | September 30th 03 09:59 PM |
