Greg,
All the explanations you got are good. Now for the carb heat check. What happens to the EGTs? FWIW, a while ago I had a too high RPM drop on the mag check with our Lyc O-360. A look at the engine monitor showed one cylinder's EGT going very high. This points strongly to one plug being fouled. A little time of running the engine at high rpm and very lean on the ground cleared the problem, which could also clearly be seen on the engine monitor. These things are worth their weight in gold, even on the simpler engines. -- Thomas Borchert (EDDH) |
PA28: Difference in constant speed prop vs fixed pitch | Nathan Young | Owning | 25 | October 10th 04 04:41 AM |
Constant speed prop oil leak | DP | Piloting | 23 | April 21st 04 10:15 PM |
Why do constant speed power setting charts limit RPM? | Ben Jackson | Piloting | 6 | April 16th 04 03:41 AM |
Practicing SFLs with a constant speed prop - how? | Ed | Piloting | 22 | April 16th 04 02:42 AM |
Constant Speed Prop vs Variable Engine Timing | Jay | Home Built | 44 | March 3rd 04 10:08 PM |
