Constant speed props
Old June 25th 04, 03:33 PM
Dudley Henriques
"GE" wrote in message
Thanks for your reply, as well as the debate on my actual intentions.
"Get
with my instructor" was implying that I will be getting the proper
training
in this aircraft from a qualified CFI. I simply wanted to increase my
knowledge prior to that instruction.
No problem, and I assumed you would be doing that. The reason I didn't
handle your post with the information you asked for is because there is
a difference between generics and specifics; and for what you will be
doing, specifics are called for. The checkout in a new complex is
aircraft specific and should be treated as such. Since you didn't state
what specific aircraft you were dealing with, I would refrain from
offering advice other than pointing you to the checkout procedure.
It's my practice that whenever a question like yours comes up without
stating what airplane the question is dealing with, I opt to steer the
poster to the checkout procedure rather than get into the specifics
requested. It's a safety issue with me......a personal preference so to
speak.
Best of luck with your checkout. I'm sure you'll do fine.
Dudley Henriques
International Fighter Pilots Fellowship
Commercial Pilot/ CFI Retired
For personal email, please replace
the z's with e's.
dhenriquesATzarthlinkDOTnzt
PA28: Difference in constant speed prop vs fixed pitch Nathan Young Owning 25 October 10th 04 04:41 AM
Constant speed prop oil leak DP Piloting 23 April 21st 04 10:15 PM
Why do constant speed power setting charts limit RPM? Ben Jackson Piloting 6 April 16th 04 03:41 AM
Practicing SFLs with a constant speed prop - how? Ed Piloting 22 April 16th 04 02:42 AM
Constant Speed Prop vs Variable Engine Timing Jay Home Built 44 March 3rd 04 10:08 PM
