I've always wondered about this suggestion? Here's what I'm thinking: If I
fly along and start getting carb ice, generally, I can apply carb heat and eventually (hopefully) eliminate the condition. At that point, I am aware that the conditions are conducive to carb ice and take whatever actions I deem appropriate. BUT,,, IF I have the carb heat on full and I still manage to ice-up, now I am in a condition that allow me few options to address - there is no other fall back at that point. Is there something I'm missing? Is the second scenario I'm describing impossible? I'd be curious about your thoughts. -- -- =----- Good Flights! Cecil PP-ASEL Student-IASEL Check out my personal flying adventures from my first flight to the checkride AND the continuing adventures beyond! Complete with pictures and text at: www.bayareapilot.com "I fly because it releases my mind from the tyranny of petty things." - Antoine de Saint-Exupery - "We who fly, do so for the love of flying. We are alive in the air with this miracle that lies in our hands and beneath our feet" - Cecil Day Lewis - "G.R. Patterson III" wrote in message ... NW_PILOT wrote: is it wise to cruise with a little bit of carb heat on in the conditions I was in today? I was taught and have read in several publications that you should always use full carb heat if you use it at all. George Patterson None of us is as dumb as all of us. |
"Cecil Chapman" wrote in message
. com... [...] BUT,,, IF I have the carb heat on full and I still manage to ice-up, now I am in a condition that allow me few options to address - there is no other fall back at that point. If you are in conditions conducive to carb ice without carb heat, then there's no way for full carb heat to produce a conditon that is still conducive to carb ice. Conversely, if you get carb ice with the carb heat full on, you are flying in some pretty cold temperatures and there was no need for carb heat in the first place. In any case, the problem with partial carb heat is that, without a carb temp gauge, you have no way of knowing that you haven't created conditions conducive to carb ice when none existed previously, or that you haven't turned conditions only a little conducive to carb ice into conditions that are very conducive to carb ice. Pete |
Cecil Chapman wrote:
BUT,,, IF I have the carb heat on full and I still manage to ice-up, now I am in a condition that allow me few options to address - there is no other fall back at that point. If you're in conditions where full carb-heat won't prevent carb-ice, what difference does it make whether you learn that full carb-heat is insufficient quickly or slowly? Is there something I'm missing? Is the second scenario I'm describing impossible? I'd be curious about your thoughts. That's why I asked whether NW had the heat hot when descending (and never saw an answer, sadly). I've never had a situation where carb-ice formed despite the heat being on. But that doesn't preclude the possibility (esp. since I'm in a very different neighborhood). I've only recently started flying aircraft that have carb-temp gauges. You can bet I'll be watching those with some curiosity. - Andrew |
difference does it make whether you learn that full carb-heat is insufficient quickly or slowly? What I meant was that one could be flying into gradually increasing severity of carb ice potential with the carb heat kept full on. That is, there wouldn't be any initial warning that conditions were becoming conducive to carb icing. If the heat was off, the very first instance of the least severe (hopefully) carb ice would begin to occur, before moving further into a condition that was conducive to even faster carb ice accretion - so perhaps, one would miss the initial 'warning' of possibly more progressively severe conditions that were waiting just a little beyond where one was flying. -- -- =----- Good Flights! Cecil PP-ASEL Student-IASEL Check out my personal flying adventures from my first flight to the checkride AND the continuing adventures beyond! Complete with pictures and text at: www.bayareapilot.com "I fly because it releases my mind from the tyranny of petty things." - Antoine de Saint-Exupery - "We who fly, do so for the love of flying. We are alive in the air with this miracle that lies in our hands and beneath our feet" - Cecil Day Lewis - |
![]() If you're in conditions where full carb-heat won't prevent carb-ice, what difference does it make whether you learn that full carb-heat is insufficient quickly or slowly? I was taught that, in general, if full carb heat brings the carb temp up to a point of icing, then using NO carb heat will keep the carb cold enough to avoid icing. I'm not sure this is true however, but in any case, colder air holds less water. Jose -- (for Email, make the obvious changes in my address) |
Yep, 100% possible I had carb heat on seemed to clear it up a bit then I
decided to descend and it iced up all the way untill engine out with carb heat on. "Cecil Chapman" wrote in message . com... I've always wondered about this suggestion? Here's what I'm thinking: If I fly along and start getting carb ice, generally, I can apply carb heat and eventually (hopefully) eliminate the condition. At that point, I am aware that the conditions are conducive to carb ice and take whatever actions I deem appropriate. BUT,,, IF I have the carb heat on full and I still manage to ice-up, now I am in a condition that allow me few options to address - there is no other fall back at that point. Is there something I'm missing? Is the second scenario I'm describing impossible? I'd be curious about your thoughts. -- -- =----- Good Flights! Cecil PP-ASEL Student-IASEL Check out my personal flying adventures from my first flight to the checkride AND the continuing adventures beyond! Complete with pictures and text at: www.bayareapilot.com "I fly because it releases my mind from the tyranny of petty things." - Antoine de Saint-Exupery - "We who fly, do so for the love of flying. We are alive in the air with this miracle that lies in our hands and beneath our feet" - Cecil Day Lewis - "G.R. Patterson III" wrote in message ... NW_PILOT wrote: is it wise to cruise with a little bit of carb heat on in the conditions I was in today? I was taught and have read in several publications that you should always use full carb heat if you use it at all. George Patterson None of us is as dumb as all of us. |
decided to descend and it iced up all the way until engine out with carb heat on. Yeah, I had that happen on my last carb ice 'adventure', but I've always presumed it was because the carburetor was ingesting large amounts of ice and water as carb heat was slowly melting the ice that had accumulated in the carb's throat - which was causing the engine to intermittently quit. That is,,,, that I had waited longer than I should have before applying carb heat and was now melting a large amount of ice that was impeding the carb throat. This suggestion is not meant to be a shameless plug, but I'd be interested to know how closely your experience paralleled with my last (i.e. carb ice prob), if you wouldn't mind taking a peek at this link to the description of my experience and could e-mail me later after reading it - telling me how closely our two experiences paralleled.... Just curious. The link is: http://www.bayareapilot.com/7700AThollister.htm email me at: -- -- =----- Good Flights! Cecil PP-ASEL Student-IASEL Check out my personal flying adventures from my first flight to the checkride AND the continuing adventures beyond! Complete with pictures and text at: www.bayareapilot.com "I fly because it releases my mind from the tyranny of petty things." - Antoine de Saint-Exupery - "We who fly, do so for the love of flying. We are alive in the air with this miracle that lies in our hands and beneath our feet" - Cecil Day Lewis - |
"NW_PILOT" wrote in message
... Yep, 100% possible I had carb heat on seemed to clear it up a bit then I decided to descend and it iced up all the way untill engine out with carb heat on. But you were descending. Along with using carb heat, one needs to remember to push the power up every now and then so that the engine is actually providing enough heat to melt the ice. Your experience isn't an argument in favor of partial carb heat. Pete |
On Mon, 28 Jun 2004 10:44:07 -0700, "Peter Duniho"
wrote: "NW_PILOT" wrote in message ... Yep, 100% possible I had carb heat on seemed to clear it up a bit then I decided to descend and it iced up all the way untill engine out with carb heat on. But you were descending. Along with using carb heat, one needs to remember to push the power up every now and then so that the engine is actually providing enough heat to melt the ice. Your experience isn't an argument in favor of partial carb heat. Did someone post the information about the recent British air authority decision that pilots could not be trusted to properly apply carb heat and that the situation ought to be taken out of their hands? The solution, they say, is to make the application of carb heat either not needed (fuel injection) or automatic, like it was for years before fuel injection in cars. Corky Scott |
4800nm trip complete! | SeeAndAvoid | Piloting | 2 | June 19th 04 05:58 PM |
Coast to coast trip finished :-) | Filip Zawadiak | Piloting | 6 | May 5th 04 08:45 PM |
8th-grader wins trip to military jet flight camp | Otis Willie | Military Aviation | 0 | January 16th 04 08:40 PM |
First long-distance trip | Marc | Piloting | 2 | December 16th 03 04:03 AM |
Reflections on first trip to Canada from US | Mike & Janet Larke | Instrument Flight Rules | 1 | August 9th 03 12:57 AM |
