Hi,
i'm based in Germany with a FAA-PPL ASEL. It's very interesting to read the differences in IFR-Flying in the States and in Germany. Although the two countries are "ICAO-countries" they are not participating in same air work to each other. Well, i think ...when learning for an IFR-Rating you should know before what you are allowed to do with it or not after passing it. I think most "VFR"-Pilots only know about the new ability to fly in clouds without reference of the ground surface. It's very interesting for me to know how the real IFR-flight is working, what problems with ATC you have when flying under IFR, the change IFR-VFR, and a lot of other things....and that....before "doing" the Rating. Thank you all for asking my questions.... Peter |
"Peter Bauer" wrote in message
om... i'm based in Germany with a FAA-PPL ASEL. It's very interesting to read the differences in IFR-Flying in the States and in Germany. Although the two countries are "ICAO-countries" they are not participating in same air work to each other. If you think Germany and the US are different, try crossing the border into other European countries. Of all of them the airspace system in Germany is most like the US, and the UK is probably at the opposite extreme. Here we have mostly class A and class G, with little between. IFR flight in class G is something we do every day -- there's not a lot of choice. Good luck if you choose to do the IR. Julian |
Julian,
most like the US, and the UK is probably at the opposite extreme. Here we have mostly class A and class G, with little between. IFR flight in class G is something we do every day -- there's not a lot of choice. IIRC in the UK you have some sort of "poor-mans-IFR" (no pun intended ;-) called the "IMC" rating, giving you the right to fly under IMC without being "in-the-system". Does that thing make it to JAR-FCL? Best Regards Kai Glaesner |
"Kai Glaesner" wrote in message
... IIRC in the UK you have some sort of "poor-mans-IFR" (no pun intended ;-) called the "IMC" rating, giving you the right to fly under IMC without being "in-the-system". Does that thing make it to JAR-FCL? Still available as a national rating valid for IFR only in the UK. The only difference from the way it used to be is that it no longer gives credit towards an IR. However, an FAA IR gives credit towards a JAA IR, and the instrument time for an IMC rating counts for the time required for an FAA IR. So we have the screwy situation that the usual "upgrade" path is IMC rating - FAA IR - JAA IR. Julian Scarfe |
Julian,
IR. So we have the screwy situation that the usual "upgrade" path is IMC rating - FAA IR - JAA IR. That's what I call "european harmonization".... ;-) Any estimates available what to spend on an IR (starting from a national PPL) in the UK? Here in germany they charge you around 13.000 EUR for that. Best regards Kai |
... Any estimates available what to spend on an IR (starting from a national PPL) in the UK? Here in germany they charge you around 13.000 EUR for that. Yes, about EUR 15,000 for a SEP-IR and about EUR 20,000 for an MEP-IR (55 hours training, not including the mandatory ground school). The problem is that while ICAO specifies 40 hours "instrument time", JAA-FCL specifies 55 hours instrument training by an approved training facility. I did mine 10 years ago under rules that allowed me to do just 28 hours (with credit for the IMC rating) in my own aircraft. Julian |
Routine Aviation Career | Guy Alcala | Military Aviation | 0 | September 26th 04 12:33 AM |
World War II Flying 'Ace' Salutes Racial Progress, By Gerry J. Gilmore | Otis Willie | Military Aviation | 2 | February 22nd 04 03:33 AM |
Flying is Life - The Rest is Just Details | Michael | Piloting | 55 | February 7th 04 03:17 PM |
Wm Buckley on John Kerry | Big John | Piloting | 22 | February 7th 04 02:19 AM |
Announcing THE book on airshow flying | Dudley Henriques | Piloting | 11 | January 9th 04 07:33 PM |
