Running runup?
Old July 1st 04, 03:01 AM
Newps
"Dale" wrote in message
Have you tried it?
Yes. At 2000 rpm I would accelerating at quite a clip. After a couple
hundred yards I'd be doing in excess of 30 mph.
  #32
Old July 1st 04, 10:00 AM
Thomas Borchert
Dale,
Have you tried it? Sure, you'll be moving faster than a "walking pace"
taxi, but not so fast as to be a hazard.
Yes. And I disagree. Definitely hazardous.
Thomas Borchert (EDDH)
  #33
Old July 1st 04, 10:40 AM
Cub Driver
On Wed, 30 Jun 2004 11:18:19 -0800, Dale wrote:
Watch an airplane during a runup with standing water on the surface.
Directly under the prop you'll see a little "mini tornado" of water
being picked up from the surface.
This is why I follow the newsgroups. You never can tell when you'll
pick up some priceless bit of information!
I look forward to my next visit to Alton Bay to see if it happens on
the lake. (Perhaps not, since the runups presumably are all running.)
all the best -- Dan Ford
email: (put Cubdriver in subject line)
The Warbird's Forum
www.warbirdforum.com
The Piper Cub Forum www.pipercubforum.com
Viva Bush! weblog www.vivabush.org
  #34
Old July 1st 04, 03:34 PM
G.R. Patterson III
If I tried to do my runup with no brakes, I'd be airborne before I finished the mag
check.
George Patterson
None of us is as dumb as all of us.
  #35
Old July 1st 04, 04:50 PM
Dale
Good grief, how long does it take you to cycle a prop? G You're only
at that power setting for a few seconds...but by all means do what
you're comfortable with.
Dale L. Falk
  #36
Old July 1st 04, 10:08 PM
Newps
Prop, mags and carb heat are done at 1700 rpm in virtually all Cessna's.
The exact rpm isn't important.
  #37
Old July 2nd 04, 05:54 AM
Dale
The Hartzell prop needs 2000 RPM.
Dale L. Falk
  #39
Old July 7th 04, 05:15 AM
Robert M. Gary
"G. Burkhart" wrote in message news:lk6Ec.1801$AI.68@attbi_s04...
When I did my training my CFI taught me to stop at the run-up area and
go through the run-up checklist. This was done at airports that had run-up
areas readily available. Fairly recently, I went with an instructor that
In the sea plane we do them during take off. You never want to move
the throttle above idle for any reason other than take off because it
picks the water up and dings the prop. You have to reduce the number
of seconds you spend at non-idle throttle.
-Robert
C-182 carb-heat causing rough running. R.T. Owning 11 November 26th 04 10:50 PM
YAMAHA FZ 750 FZ750 RUNNING GENESIS ENGINE FOR SALE Karsten Home Built 0 September 3rd 04 07:34 PM
Rotax 503 won't stop running Tracy Home Built 2 March 28th 04 04:56 PM
Leaving all engines running at the gate John Piloting 12 February 5th 04 03:46 AM
