"Snowbird" wrote in message
m... I'll be interested in what others say, but my take on this is: As far as I know, all the V-speeds you're talking about are a direct function of stall speed. For landing, true. For takeoff, not true. Vx and Vy, being the result of excess thrust and excess power (respectively), depend not just on the fixed characteristics of the airframe, but also the declining characteristics of the engine (and are not directly related to stall speed in any case). Now, that said, I agree with the others who point out that if the airplane's performance has changed enough that the published V speeds are not correct, then the airplane needs fixing. A slight reduction in engine power might be expected, but one large enough that Vx and Vy have changed enough for the pilot to notice warrants repair. And as you say, even the airframe can suffer during its lifetime in ways that might affect stall speed. But again, I'd say that if the stall speed has increased above the published speeds, the correct course of action is to fix the airplane. And generally speaking, I wouldn't expect the stall speed to change in a way noticeable to any but the most detail-oriented test pilot; changes in gross weight are going to be much more significant, and those mostly occur due to differences in loading (how many passengers, what weights, amount of fuel carried, etc.). 30 pounds of accumulated junk, while not unheard of, is still unusual, and even that much extra weight isn't going to produce a noticeable change on the airspeed indicator when stalling the airplane. I'm in complete agreement that it's foolish to add airspeed on landing. The extra speed might put you farther away from some problems (premature stall) but it's guaranteed to put to closer to other problems (long landing, porpoising, nose strike, etc.). Adding airspeed to compensate for gusts is reasonable, but adding airspeed just because you think the airplane is old is not, and is unsafe. Pete |
"Peter Duniho" wrote in message ...
"Snowbird" wrote in message m... I'll be interested in what others say, but my take on this is: As far as I know, all the V-speeds you're talking about are a direct function of stall speed. For landing, true. For takeoff, not true. Vx and Vy 'Scuse, Peter, but I said "all the V speeds you're talking about", not "all V-speeds". As best I can tell, the original poster was talking about Vr, and landing speed. I don't think he discussed being asked to climb out at a different speed than Vx or Vy, but in any event I think a better argument can be made for that practice in appropriate circumstances. Now, if you want to argue for Vr being a function of excess thrust and excess power -- go ahead. Cheers, Sydney |
om... 'Scuse, Peter, but I said "all the V speeds you're talking about", not "all V-speeds". As best I can tell, the original poster was talking about Vr, and landing speed. Whatever. I find Vx and Vy to be perfectly relevant in this thread, even looking at only the first post. You want to be offended, go right ahead...wouldn't be the first time. |
"Snowbird" wrote in message om... 'Scuse, Peter, but I said "all the V speeds you're talking about", not "all V-speeds". As best I can tell, the original poster was talking about Vr, and landing speed. Whatever. I find Vx and Vy to be perfectly relevant in this thread, even looking at only the first post. You want to be offended, go right ahead...wouldn't be the first time. Vx and Vy are certainly relevant to bring into the discussion, but they weren't mentioned in the original poster's description, and I referred to that. You were responding to my post, and saying "not true" to me. I simply clarified what I'd meant. That doesn't mean that Vx and Vy aren't relevant to introduce, as additional factors which *are* dependent on factors other than stall speed. It's a reasonable point -- provided it's not introduced in a way which puts words into someone else's mouth or refutes a claim they weren't making. I await your explanation of Vr and what it depends upon, and I note that one can fly behind an engine later shown to have one cylinder completely flat, and not notice any particular changes to Vy, the rate of climb obtained at that speed (under DA conditions not near the edge of the envelope, admittedly), or cruise airspeed. Cheers, Sydney |
om... I await your explanation of Vr and what it depends upon I've never flown an airplane with a published Vr. Since you're the one making claims about how it's determined, how about YOU explain Vr and what it depends on. As far as Vy and Vx not varying with engine power (your claim regarding "one cylinder completely flat"), you may not have noticed the difference in the cockpit, but that doesn't mean they didn't change. Pete |
![]() "Michael" wrote: What you say is true, but only because what you refer to as a completely flat cylinder is not in any way equivalent to a cylinder not making power. A completely flat cylinder is what a mechanic will call a cylinder that is not anywhere close to making compression in a static test - meaning it only makes, say, 20/80 or even less. I have in fact had this happen - ...There was no noticeable impact on performance, Yep, I've even had this happen on *two* cylinders on the same side of a LYC O-360 and noticed nothing until a just-for-the-hell-of-it compression test revealed the bad news. The engine was running nice and smooth. -- Dan C172RG at BFM |
Someone correct me if I'm wrong, but changes in engine performance
wouldn't affect Vx or Vy would they? It might affect the power settings necessary for these speeds, or the plane effectiveness in holding them, but my understanding is that Vx and Vy are determined by the aerodynamics of the design of the plane and it's weight. Changes in an engines performance with age shouldn't affect these speeds, should they? Snowbird wrote: "Peter Duniho" wrote in message ... "Snowbird" wrote in message .com... 'Scuse, Peter, but I said "all the V speeds you're talking about", not "all V-speeds". As best I can tell, the original poster was talking about Vr, and landing speed. Whatever. I find Vx and Vy to be perfectly relevant in this thread, even looking at only the first post. You want to be offended, go right ahead...wouldn't be the first time. Vx and Vy are certainly relevant to bring into the discussion, but they weren't mentioned in the original poster's description, and I referred to that. You were responding to my post, and saying "not true" to me. I simply clarified what I'd meant. That doesn't mean that Vx and Vy aren't relevant to introduce, as additional factors which *are* dependent on factors other than stall speed. It's a reasonable point -- provided it's not introduced in a way which puts words into someone else's mouth or refutes a claim they weren't making. I await your explanation of Vr and what it depends upon, and I note that one can fly behind an engine later shown to have one cylinder completely flat, and not notice any particular changes to Vy, the rate of climb obtained at that speed (under DA conditions not near the edge of the envelope, admittedly), or cruise airspeed. Cheers, Sydney |
"Matt Young" wrote in message
news ![]() Someone correct me if I'm wrong, but changes in engine performance wouldn't affect Vx or Vy would they? As I mentioned before, Vx and Vy are functions of excess thrust and power, respectively. In particular, they are the airspeeds at which excess thrust and power are at their maximum. If thrust were constant, Vx would happen at minimum drag airspeed regardless of engine power. But thrust isn't constant; it varies with airspeed, and the airspeed at which the thrust in excess of drag is at its maximum depends on how much engine power you have. For the same reason that thrust isn't constant (propeller efficiency changes with airspeed), power isn't constant either, and again, the airspeed at which the power in excess of power required for level flight is at its maximum depends on how much engine power you have. You can demonstrate for yourself that Vx and Vy depend on engine power, by considering the difference between relevant airspeeds when there's no engine power. Best glide airspeed isn't the same as Vx, even though both airspeeds provide the best performance of the aircraft in terms of altitude change over distance. Likewise, minimum sink airspeed isn't the same as Vy, even though both airspeeds provide the best performance of the aircraft in terms of altitude change over time. Generally speaking, the differences between all of these airspeeds isn't huge, but it's important to understand that they aren't the same. [...] Changes in an engines performance with age shouldn't affect these speeds, should they? Not significantly enough for the published speeds to be unusable. If the engine performance has changed enough to affect Vx and Vy significantly, there's something wrong with the engine. But it's false to say that they aren't affected at all. Pete |
GPS/WAAS VNAV approaches and runway length | Nathan Young | Instrument Flight Rules | 8 | October 25th 04 06:16 PM |
What approaches are in a database? | Ross | Instrument Flight Rules | 11 | January 4th 04 07:57 PM |
"Best forward speed" approaches | Ben Jackson | Instrument Flight Rules | 13 | September 5th 03 03:25 PM |
Logging instrument approaches | Slav Inger | Instrument Flight Rules | 33 | July 27th 03 11:00 PM |
Garmin Behind the Curve on WAAS GPS VNAV Approaches | Richard Kaplan | Instrument Flight Rules | 24 | July 18th 03 01:43 PM |
