Running runup?
Old July 1st 04, 10:08 PM
Newps
"Dale" wrote in message
"Newps" wrote:
Yes. At 2000 rpm I would accelerating at quite a clip. After a couple
hundred yards I'd be doing in excess of 30 mph.
Good grief, how long does it take you to cycle a prop? G You're only
at that power setting for a few seconds...but by all means do what
you're comfortable with.
Prop, mags and carb heat are done at 1700 rpm in virtually all Cessna's.
The exact rpm isn't important.
Old July 2nd 04, 05:54 AM
Dale
The Hartzell prop needs 2000 RPM.
Dale L. Falk
C-182 carb-heat causing rough running. R.T. Owning 11 November 26th 04 10:50 PM
YAMAHA FZ 750 FZ750 RUNNING GENESIS ENGINE FOR SALE Karsten Home Built 0 September 3rd 04 07:34 PM
Rotax 503 won't stop running Tracy Home Built 2 March 28th 04 04:56 PM
Leaving all engines running at the gate John Piloting 12 February 5th 04 03:46 AM
